Old 04-06-2006, 06:52 PM   #1 (permalink)
Wink will Solaris work on AMD
hi,
can anyone tell me whether Solaris 8 works on an AMD processor
AMD3200+
bye
naveen224 is offline
Old 04-06-2006, 07:53 PM   #2 (permalink)
Default Re: will Solaris work on AMD
Yes it works. I am using it for the last month or so. The AMD cpu is capable of executing i386 code and thats what makes it execute all intel specific sw/os.
**** happens
pradeep_chauhan is offline
Old 05-06-2006, 10:16 PM   #3 (permalink)
thank you pradeep, do you know which AMD processor is best to buy inplace of Pentium 4 HT 3GHz,and is Pentium 4 32 bit or 64 bit processor
