MM buttons on my keyboard are behaving strangely.
some of the buttons don't work. (mute)
some work fine.
calculator shows up two times when its button is pressed.
and audio controls (play/pause/stop etc) works only when real player is in focus.
whts happening?
pl suggest some remedy.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
Hi guys,
I recently bought a frontech mm keyboard. I use winXP. The keyboard works fine. The mm part does not. I tried installing the driver it came with. However the setup exits stating that mm keyboard is supported by winxp. I searched winxp add-remove windows components but nowhere did I find a way to install winxp inbuilt support for mm keyboard. Can anyone help?
some work fine.
whts happening?
Try uninstalling the device and re-boot ur system....
if it works fine then there was some problem with the drivers....but if it does not the problem may be with ur hardware,....
