Old 04-06-2006, 01:04 AM   #1 (permalink)
Default Check Overheating???
How to check whether the system is overheating or not?????
ashishkhetriwal is offline
Old 04-06-2006, 06:48 AM   #2 (permalink)
The pWnster
Vyasram's Avatar
Default Re: Check Overheating???
use motherboard monitor or check through ur bios the sys temp and check whether it falls within the maximum allowed limit
Sigs suck
Vyasram is offline
Old 04-06-2006, 09:50 AM   #3 (permalink)
Eazy's Avatar
I use the FREEWARE Sensorsview 1.2 ... check out image...
Eazy is offline
Old 04-06-2006, 12:32 PM   #4 (permalink)
ashfame's Avatar
ur temp are ok but ur fans are moving slowly.
most of the fans has a rpm of about 5k.
please check if ur cpu fan has accumulated dust over it but i don't think so coz temp. is ok.
dunno about the voltages.
wait for others to confirm.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 04-06-2006, 07:05 PM   #5 (permalink)
samrulez's Avatar
U can use Mother Board monitor...or any other ...there are many such softwares.Which mobo do u have?
Sam :D Rulez :lol:
samrulez is offline
Old 04-06-2006, 10:52 PM   #6 (permalink)
Ashfame that was just an screenshot of the software. BTW the speed of cpufan is quite fine. If it has dust on fan or heatsink , the temp. of processor will rise and hence cpu fan speed
cyrux is offline
Old 05-06-2006, 03:09 PM   #7 (permalink)
deathvirus_me's Avatar
Well .. u can't actually check overheating ... what u can do is use tools like ATi Tool or Prime 95 and stress out ur system ... and see how long ur system manage to run stable .. and keep the temps monitored the whole time via speedfan etc. ... If u find ur system stable for a very long period of time ... say 10 hrs. at a stretch .. then u need not worry much ....
Also ... better cooling can ensure lower temps. which translate into better stability and longer usage ..... i'd say make sure ur load temps are around 50c for the processor , and around 40c for the rest of the components ....
deathvirus_me is offline
Old 08-06-2006, 03:18 AM   #8 (permalink)
TechGuru#1's Avatar
EVEREST HOME ULTIMATE EDITION.......mayb that an answer!
TechGuru#1 is offline
Old 08-06-2006, 03:32 AM   #9 (permalink)
use CPU COOL
Home page >>HERE<<
Download >>HERE
U can also control overheating
PM for help
hermit is offline
Old 09-06-2006, 12:08 AM   #10 (permalink)
King of my own Castle
freshseasons's Avatar
CPU cool is not at all going to help you if you are using windows xp. Under WIN2000 and XP you dont need CPU Cooling software because this Operating systems has this function these functions built in.
This systems executes automatically the HLT-command, whether there is CPU-cool or Cpu-idle or other softwares.
CPU Cool is here therefore superfluous.
freshseasons is offline
Old 09-06-2006, 05:27 AM   #11 (permalink)
see this now is it clear cpu cool work instead of system ideal
it also under systems at high temp to prevent ovr heating .
i see difference on AMD .
hermit is offline
