03-06-2006, 09:11 PM
RAM query
these are the reports by everest:
I hav two systems:
System 1:
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-021604-iBRKDL_G$VA84510A_BIOS DATE: 02/16/04 02:29:53 VER: 08.00.08
Motherboard Name Intel Sea Breeze D845GVSR
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 133 MHz (QDR)
Effective Clock 533 MHz
Bandwidth 4267 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 3 PCI
RAM Slots 2 DIMM
Integrated Devices Audio, Video
Form Factor Micro ATX
Motherboard Size 210 mm x 240 mm
Motherboard Chipset i845GV
System 2:
Motherboard ID 63-0100-000001-00101111-062204-iSPGDL_G$BF865001_BIOS DATE: 06/22/04 03:49:15 VER: 08.00.10
Motherboard Name Intel Bay Field D865GBF
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Bus Width 8-bit
Bandwidth 267 MB/s
CPU Sockets/Slots 1
Expansion Slots 6 PCI, 1 AGP
RAM Slots 4 DIMM
Integrated Devices Audio, Video, LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset i865G
I need to buy 512 MB DDR ram for both of these.
why it is showing ram to be DDR SDRAM
What are real clock & effective clocks?
Which frequency of ram will be compatible with the two mobos?
coz 512MB @ 266Mhz aren't available!!
One vendor told me that 333Mhz will be compatible but 400Mhz will be a NO NO.
is it true??
can i buy 512 ddr ram @ 333mhz for both of the systems??
pl help its a kind of urgent.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
03-06-2006, 09:21 PM
Your Maker.
Re: RAM query
Real Clock= original frequency (instruction-per-second)
effective clock=original frequency*multiplier
In case of DDR(double data rate), multiplier=2, in case of QDR(quadruple), multiplier=4
But u have posted the FSB clocks.
In everest, go to motherboard and then go to SPD. See the RAM clocks and Latencies there and buy a memory accordingly.
EDIt: Ahh. got it...get DDR RAM @ 266 Mhz for mobo 1 and DDR RAM @ 400 for mobo 2
“Talent is a flame, but genius is a fire.”
03-06-2006, 09:31 PM
Re: RAM query
ddr 400 should run at 266 in such cases, please confirm though
03-06-2006, 09:33 PM
Re: RAM query
The ram frequency is 133 (SD) MhZ so in DDR i.e Double Data Rate the speed of the SD ram is doubled i.e 266 MhZ.....That is why DDR modules are called DDR SD rams..
Sam :D Rulez :lol:
Re: RAM query
but 512mb ddr ram @ 266mhz not available in market.
should i go for 333mhz ram for mobo 1.
thanks in advance.
03-06-2006, 09:36 PM
Your Maker.
Re: RAM query
Get a RAM that runs at dual frequencies, like 333(higher) and 266(lower) or 400(higher) and 266(lower)
03-06-2006, 09:41 PM
Re: RAM query
what if i am unable to get dual frequencies ram?
And 400mhz ram for mobo 2 is confirmed na?
will 400mhz ram work in mobo 1?
can the ram sticks get damaged if unmatched frequencies are matched or something?
04-06-2006, 12:05 AM
Your Maker.
Re: RAM query
Yeah, 400 Mhz for Mobo 2 will work just fine.
Lemme clear this....400 mhz may or may not work with mobo 1.....depends on the make..and as i said..if it has dual operating frequencies. My suggestion wud be--get a 512 MB @ 400 Mhz stick for mobo2...and try it also on mobo 1. If it works, then fine..get another one...if it doesnt...well we'll see that later.
I'll search the net and let u know if i find a dual frequency stick suited to ur need
EDIT: aha! Found the Intel specifications for mobo 1 : HERE It says the mobo s'ports 333/266/200 Mhz of speeds @ 2gb DDR ram max.
04-06-2006, 10:15 AM
Re: RAM query
thanks to samrulez.
thanks a lot to mystichalo. (i liked ur previous avatar more)
i will be buying 512MB DDR ram @ 333mhz for mobo 1 & @ 400Mhz for mobo 2 on monday.
One more ques.
processors that indicate their FSB are real clock or effective clock?
04-06-2006, 07:09 PM
Re: RAM query
thanks to samrulez.
One more ques.
I think the indicated FSB is the real clock...and with the multiplier it is the effective clock....Am I right?
Sam :D Rulez :lol:
04-06-2006, 07:15 PM
Re: RAM query
Well u should be able to find a 512 ddr266 modue ... a little search should do it ...
Also ... all ddr ram are compatible with each other irrespective of the frequency ... when two diff. frequency modules are used , the lower frequency is chosen as the operating frequency .... so u should face no problem ...
The only restriction u might face is the latency variations which might result in a very low oc'ing probability ....
04-06-2006, 07:53 PM
Re: RAM query
thanks in advance.
I`m also using 512mb [Kingston] ( 400mhz )[Value Ram ]DDR ram with my old motherboard 845 & It`s Working fine .BUt remember one thing ram will clock at 266Mhz
04-06-2006, 08:11 PM
Re: RAM query
Pl explain. I don't get it.
for an example:
Pentium D 805 has a FSB of 533mhz.
this 533mhz is real clock or effective clock?
Now wht that means?
04-06-2006, 08:26 PM
GaurishSharma.com
Re: RAM query
ash one sussestion pls post repots as in code or quotes
04-06-2006, 08:33 PM
Re: RAM query
@ gary
thanks for suggestion
i hav edited it.
can u pl PM all the tags syntax that can be used such as smileys,img etc.
04-06-2006, 08:36 PM
Re: RAM query
for an example:
See 533 MhZ is the real clock and 533*5=2665 MHZ (the clock speed of the proessor) is the effective clock...I..think...
Sam :D Rulez :lol:
04-06-2006, 08:41 PM
Re: RAM query
can someone pl confirm
05-06-2006, 03:22 PM
Your Maker.
Re: RAM query
Yeah, he's correct.
Processor Clock=FSB * Multiplier.
This is a very common change made during oveclocking...increasing the multiplier setting through the motherboard. Hence, if ur current setting is 2.6 Ghz (533*5), then if u change multiplier to 5.5, the resulting frequency will be (533*5.5)=2.8 Ghz approx., an overclock of 200 Mhz approx.
As for latency, its the delay between transfers in RAM mdules. Higher the latency, higher the delay. Mostly, u'll get modules of local makes like Hynix and Zion with higher latencies whereas costlier modules like those of Corsair and Kingston generally provide lesser latencies.
As far as my avatar is concerned, i'll be changing soon.....maybe a FIFA WC avatar
05-06-2006, 03:41 PM
#19 (permalink)
Re: RAM query
Well .. if i remember correctly i had my ddr266 latencies defaulting at 2.5,3,3,6 ... now .. the ddr400 modules that i use is rated at 2,2,2,6 at ddr266 .... so if i run the ddr400 with my older ddr266 modules .. there will be a bit of a default latency conflict ... so the mobo will detect the ideal stable lantency for both types .. which infact will be 2,2,2,6 ... although the ddr266 modules should run perfectly at those latency .. there's still the word "forced" involved ...
Well . there is something known as "price" .... even zion has low latency editions .... but they will costs a lot more ... for a budget user these are much better ,, coz then a 150 MBps in mem. read/write speed will make a little diff. .... Also ... if ur a nForce mobo owner .... and running an Athlon64 .. lower latencies may not always be better ,,,, like in my case , 3,3,3,8 does better than 2.5,3,3,6 .... about a solid ~100 MBps diff. (more in the higher latencies) ...
05-06-2006, 03:42 PM
#20 (permalink)
Re: RAM query
Its showing DDR SDRAM instead of DDR RAM because the name of the RAM is DDR SDRAM - Double Data Rate Synchronous Dynamic Random Access Memory instead of wat its popularly known as - DDR RAM thanx to our great system assembler community in India who r careless to the lot and diffrentiate between the older RAMs by calling the SDRAM which is actually SDR SDRAM ie Single Data Rate Synchronous Dynamic Random Access Memory
05-06-2006, 03:51 PM
#21 (permalink)
Re: RAM query
Hmm ... strange .. the multiplier is much higher i think .... ... when using standard ddr400 modules .. the ram operates at 200 MHz and the FSB at 533 MHz ( CPU : FSB ratio is more than 1:1 then ..) .... FSB / 2 = 266 MHz ... so in this case the multipler should be 10 ... not 5 ....
05-06-2006, 08:07 PM
#22 (permalink)
Re: RAM query
what if i plug in a 400mhz ram in mobo 1 which only supports 333/266/200mhz?
will the ram or mobo gets any damage?
And regarding FSB stuff, i am asking the fsb indicated for Pentium D 805 is 533mhz.
now this 533mhz is real clock / effective clock ?
05-06-2006, 08:18 PM
#23 (permalink)
Re: RAM query
No,it will not damage the mobo..but it will work at only 333 MHz instead of 400 MhZ
533 Mhz is the real clock ..when u include the FSB also it the effictive clock i.e the main core clock speed
Sam :D Rulez :lol:
05-06-2006, 08:29 PM
#24 (permalink)
Re: RAM query
gary suggested me a mobo for my proci. (SYSTEM 1)
see this :
Mobo for 478 socket processor
the mobo supports 533mhz & 800mhz proci.
my real clock is 133Mhz. & effective clock is 133*4 = 533mhz.
can i hav that mobo?
how can i confirm that the mobo wants 533mhz as its real/effective clock speed?
06-06-2006, 01:20 PM
#25 (permalink)
Your Maker.
Re: RAM query
Yeah, a mobo wid s'port for 533 Mhz proccy should work just fine. everythin we refer in speeds is the final effective clock and not the real clock. So ur FSB for Proc.1 is basically 533 Mhz (133 Mhz is the FSB of my P3 :lol)
06-06-2006, 03:37 PM
#26 (permalink)
Re: RAM query
so if pentium d 805 has a real clock of 533mhz, then how much is its effective clock?
06-06-2006, 04:22 PM
#27 (permalink)
Your Maker.
Re: RAM query
533 Mhz is the effective clock of the fsb
09-06-2006, 10:29 AM
#28 (permalink)
Re: RAM query
i hav just installed 512mb ddr @ 400mhz ram in my frnds comp. but now it is making the windows to restart randomly & every app. is giving error (like that says send & don't send)
wht could be the prob?
is the ram faulty?
pl its really urgent.
09-06-2006, 11:53 AM
#29 (permalink)
Re: RAM query
Not necessarily, this could be incompatiblity of ram if its along with another module. What freq. doest the motherboard support . Is this ram installed with another one. If yes what is its freq ?
09-06-2006, 02:26 PM
#30 (permalink)
Re: RAM query
Go to the BIOS and and run the 2 memory modules at the same speed....Check wheather both the modules are pluged in properly.....
Sam :D Rulez :lol:
