Old 03-06-2006, 08:02 PM   #1 (permalink)
tiblu's Avatar
Question 3 Harddisk Crashed in 1 Hour
hey guys i m in big, serious problem my college's professor called me he said that having trouble with pc. The message displayed before boot options that disk error at apai 0 disk 0 and cannot boot. I then pluged secod hdd at primary it booted and then when i first restarted after installing winxp it again showed same msg. and with the third hdd whch i brought. help.
tiblu is offline
Old 03-06-2006, 08:26 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: 3 Harddisk Crashed in 1 Hour
try changing the cables, i think they might be the faulty ones
techtronic is offline
Old 03-06-2006, 09:01 PM   #3 (permalink)
Default Re: 3 Harddisk Crashed in 1 Hour
change the cable and ck the power supply ... also fuse and anti-spike rnt working properly
hellomotto is offline
Old 03-06-2006, 09:28 PM   #4 (permalink)
samrulez's Avatar
If there is a cable problem it will be solved by replacing them...but if the hard disks have really crashed then.....
In some mobos the Southbridge (SATA/PATA controllers) are not locked from the main bus...so when u increase the FSB the southbridge is also overclocked thus crashing the hard disk....
Disconnect all the hard disks and start the computer and check wheather nothing is overclocked from the BIOS..OR "Load default settings" in the BIOS..
But, first check the hard disks in some other computer....if it works then the hard disk is fine, if not then the SATA/PATA controllers are faulty..
Sam :D Rulez :lol:
samrulez is offline
Old 03-06-2006, 11:06 PM   #5 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
did u try the bad hdds in another system...
cause it could be due to bad/burnt idecontroller on the mobo
Rollercoaster is offline
Old 04-06-2006, 06:50 PM   #6 (permalink)
Pharmaguru
kjuvale's Avatar
My friend was having same problem, he blowed 4 HDDs in one day. (got replaced because of guarrenty) . There was problem in his mainboard. Check your mainboard.
As samrulez said check on different pc
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 04-06-2006, 08:34 PM   #7 (permalink)
phatratt's Avatar
the problem could be with the faulty IDE controller,datacable or with the power connector.If the problem occurs on primary channel then try on the secondnary,if both fails,then the mobo is at fault.As for the hdd try it on an alternate pc to make sure they are working properly.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 05-06-2006, 10:56 AM   #8 (permalink)
tiblu's Avatar
I hav checked the HDD on my system they hangs on startup cant even go to bios and makes niose like kat-kat-kat sound really loud.
tiblu is offline
Old 05-06-2006, 11:03 AM   #9 (permalink)
that means yr harddisk has some serious problems... it never makes a loud noise unless an untill something is scratching the magnetic plate... do not connect them as it will be really difficult to recove rthe data if the hdd is phyiscally damamged
mangemayur is offline
Old 05-06-2006, 11:15 AM   #10 (permalink)
tiblu's Avatar
Could it b bcoz not having earthing, i got really bad shock when i touched the cabinet.
tiblu is offline
Old 05-06-2006, 04:01 PM   #11 (permalink)
phatratt's Avatar
earthing has got nothing to with it,i used to get shock when ever i touched my cabinet or any metal parts inside and hdd are still working fine.
phatratt is offline
Old 05-06-2006, 08:26 PM   #12 (permalink)
As far as I know, proper earthing is most important in case of a computer and especially for the HDD.
In fact it is the first thing to check before connecting a system to the power supply. (by checking the voltage between Earth and Neutral)
V.Prem Kumar
janitha is offline
