Old 03-06-2006, 03:07 PM   #1 (permalink)
Exclamation mouse problem
guys i have got a terible thing with my mouse ...my mouse movess only horizontally and does not moves vertically .
whats the problem .....plz help
how do u track a SIFIR :-)
chetan.g is offline
Old 03-06-2006, 03:20 PM   #2 (permalink)
khansdream's Avatar
Talking Re: mouse problem
Are u still using Magnetic mouse.................?????????
khansdream is offline
Old 03-06-2006, 05:52 PM   #3 (permalink)
phatratt's Avatar
Default Re: mouse problem
which type of mouse r u using?mechanical or optical(it can happen)the X and Y coordinates inside the mouse(mechanical)could be misaligned or damaged or too much dust inside,just open it up and clean it.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 05-06-2006, 02:39 PM   #4 (permalink)
Thanxx 4 Replyin' ......... I'm Using Both Optical And Scroll Mouse On A Ps2 Port ....... Also I Have Reinstall The Windows And Still Problem Is There ..(so The Drivers Are Also Alright)..... I Have Connected Fine Workin Mouse Of My Friend To My Pc , But The Problem Still On ....... Whts The Problem I Cant Understand ....the Mouse Flikers Very Much ...some Hardware Eng. Says Its The Problem Of Ps2 Port ... Now What I Have To Do ?? Any Suggestions Plzz
chetan.g is offline
Old 05-06-2006, 03:55 PM   #5 (permalink)
phatratt's Avatar
then th problem could be with the ps2 port,it could be damaged,try using a usb mouse or a serial port one.
phatratt is offline
