Re: MX 518 sensitivity
dpi = dots per inch, basically higher dpi = faster movement at same sensitivity, matlab sensitivity automatically increases...
if u play cs, then here's wat to do, just chk out ur windows sensitivity, how many notches is it?? and if enhance pointer precision is on...i wouldnt recommend using the logitech setpoint software, if ur into serious gamin, coz its just not possible to install the software wherever u go...
without installing the software, there r 3 DPIs available, 400, 800, 1600, so all u have to do is note the windows mouse settings (in control panel -> mouse -> pointer options) and the cs sensitivity, and also keep mouse filter off...
so when u goto a cafe, just change the windows sensitivity to wat u use, and the ingame sensitivity to wat u use, like 1.4...
for exaample, i use mx518, without the software, at 1600 dpi, windows sensi 4 notches, enhance precision off, ingame 1.8, mouse filter off...so u have to keep these settings in all the PCs that u use, windows sensitivity is a must...
Athlon 64 2800+ | MSI K8M-Neo-V | Seagate 160 GB PATA | 512 MB Simmtronics DDR400 | Creative Inspire 5200 5.1 | Philips 107E5 17\" Monitor | Sony DVD-CDRW | Microsoft Internet Keyboard+Logitech MX518 | XFX Geforce 6600GT 128MB AGP |
