Old 02-06-2006, 02:34 PM   #1 (permalink)
Exclamation MBR problem!!!
I have a Western Digital Drive.
It is not detected by the BIOS.
When another HDD is connected, the Western Digital Drive is detected but the problem is that Windows XP Setup cannot access the Western Digital Drive. I tried using Seagate utility software but even that also is not able to access the HDD. Both XP setup and seagate tool detects the HDD but is not able to access the HDD. What problem is it and is there any solution to rectify it? I think that it is a MBR problem, so if it is a MBR problem,can anyone refer me a nice MBR software to rectify the HDD problem.
deepankars2002 is offline
Old 02-06-2006, 04:06 PM   #2 (permalink)
Default Re: MBR problem!!!
Can u specify
1) which Motherboard u r using?
2) What is Capacity of the Hard Disk?
Sharing Knowledge Expands Horizon... And Problems r solved
bikram_singhy is offline
Old 02-06-2006, 05:32 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Try enabling "large" access mode in bios.
kalpik is online now
Old 02-06-2006, 06:10 PM   #4 (permalink)
khansdream's Avatar
Arrow Re: MBR problem!!!
Contact bikram_singhey, he will replace ur hdd to a new one....!!!! (check for his thread)
Well, if u r sure that u got MBR problem, format ur hdd leaving first few cylinders.
khansdream is offline
Old 02-06-2006, 07:14 PM   #5 (permalink)
::vicky::'s Avatar
update ur bios
::vicky:: is offline
Old 02-06-2006, 10:57 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
hey if it is a sata drive(open the case and search for orange wire connecting hdd) then u need to install sata drivers from floppy.if not try solution quoted by others.
gary4gar is offline
Old 02-06-2006, 11:01 PM   #7 (permalink)
deathvirus_me's Avatar
What hdd ru using ??? and mobo ???
deathvirus_me is offline
