Old 02-06-2006, 12:01 AM   #1 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Dataone and Airtel Broadband - USB Slot Problem
i installed the bsnl broadband dataone connection in one of my friend's house. but whenever i use the connection, it disconnects within one hour.
i personally checked the ip,dns and dhcp configuration. the username and password also are correctly entered.There is no ethernet card attached.
The modem has usb configuration.
The same problem is also occuring in another person's house who also has usb configuratuon who has airtel broadband using beetel modem.
When contacted, the customer care people say that this may be due to pirated versions of windows XP. if this is true, then it ok , if its not
then what might be the possible cause be for this disconnection ?
techtronic is offline
Old 02-06-2006, 12:34 AM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: Dataone and Airtel Broadband - USB Slot Problem
i think there is setting in modem but i could not figure out clearly. but certainly its not the p****d xp
gary4gar is offline
Old 02-06-2006, 12:39 AM   #3 (permalink)
I have suffered the same problem with beetel modem. I use airtel. The problem was rectified by changing modem from beetel to r.b. comtec.
amitgg is offline
Old 02-06-2006, 05:31 AM   #4 (permalink)
eagle_y2j's Avatar
Smile Re: Dataone and Airtel Broadband - USB Slot Problem
Sometimes Frequent disconnection is caused due to Power Surge or some other type of distrubance in BSNL bfone line. As ADSL connection is very sensitive and a high electric surge can cause port blocking for safety at local BSNL exchange which results in disconnection in some cases it can cause total link faliture .So it seems ur frnds bfone line need to be checked by BSNL Broadband team so plz contact them if other solutions doesn't work.....................Pirated window can't be a culprit as mine shows nop lol
Registered LINUX USER #438929
eagle_y2j is offline
Old 02-06-2006, 09:55 AM   #5 (permalink)
Well i have heard of similar problems with people using usb port, try using ethernet if possible
cyrux is offline
Old 02-06-2006, 09:56 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
check for voltage supply in ur house. some adsl modems are senstive that much that a small up down leads to discountion.use a ups if nessary.
gary4gar is offline
Old 02-06-2006, 11:11 PM   #7 (permalink)
mohit sharma's Avatar
cyrux is right , try using ethernet , infact dsl installation team of airtel prefers ethernet link for installation and gives usb connection cable as a backup only . the reason according to them is that usb connection requires some special drivers and if any single file of tht driver file gets corrupted anyway then it will create problem .
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
mohit sharma is offline
