Old 01-06-2006, 04:29 PM   #1 (permalink)
tiblu's Avatar
Question Directx 10 Vs Directx 9
hey guys i dont know about technical difference between them but i had a question. What happen when i install directx 10 with vista, i know winxp wont hav directx 10, so can i plan D10 games on my D9 Graphic Card, or can i play D10 games on WinXp. Is D10 backward compatible with D9 cards.
tiblu is offline
Old 01-06-2006, 04:38 PM   #2 (permalink)
Default Re: Directx 10 Vs Directx 9
dx 10 isn't out and won't run anyways on win xp
no dx 10 is out right now either
a dx 10 game can't run on a dx 9 card unless it supports dx 9 as well
akshayt is offline
Old 01-06-2006, 06:30 PM   #3 (permalink)
The pWnster
Vyasram's Avatar
game devs know dat a majority wd stick with xp, so the games 'll be compatible on dx9
Sigs suck
Vyasram is offline
