1. Can anyone suggest the cheapest processor+mobo combination?
AMD/Intel doesn't matter. Mobo should hav onboard sound card.
2. How much does the cheapest cabinet costs?
3. Cheapest 80gb hdd? (is it available in 5400rpm)
4. How much does a dot-matrix printer costs?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
P III 600 Mhz, GeForce 2 MX, Samsung Samtron 45B(n), Zoltrix 4 Channel Sound, Hynix 256 MB SDRAM 133 MHz, Samsung SM 352 BM Combo Drive
Since every dog has its Day
I will have mine too
AMD is a better choice, all motherboards now come with onboard sound. A 64bit sempron with a asus k8v-mx would be ideal and enough for the given needs. Cabinet with SMPS will set you back by a grand or so. 80 gig hdds are now entry entry level, get a 7200rpm hdd. It makes a lot of difference and the price difference is just a few hundreds. Dot matrix printers are costly, Espon or TVS are the main players which cost around 8k.
well i will try that.
thanks guys & will get back on this topic after 12 jun coz before that i don't hav time to assemble this one now. it can wait. gotta handle some new PCs & my papers.
