Old 31-05-2006, 05:00 PM   #1 (permalink)
ashfame's Avatar
Wink Mobo for 478 socket processor
i hav a 478 socket P4 with Intel Sea Breeze D845GVSR mobo.
it don't hav a AGP or PCIe slot, so pl suggest me a cheap but good mobo with a pcie 16x slot which has nothing less in features than my current one.
i wish to buy one 7600gt. (all the budget goes here)
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 31-05-2006, 05:59 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Mobo for 478 socket processor
Nopes there aint any mobo with PCI support for socket 478. U can go for D865/75 chipsets... it supports 8x agp and u might get a good card in those... not 7600GT i guess
Harsh J
www.harshj.com
QwertyManiac is offline
Old 31-05-2006, 07:53 PM   #3 (permalink)
ashfame's Avatar
so suggest me a AGP 8x based mobo that supports DDR.
Is frequencies of RAM & Processor are also considered while looking for a mobo?
I think 6600gt 256MB is available for AGP 8x slot.
kindly post how much performance will it give as compared to its pcie 16x variant?
ashfame is offline
Old 31-05-2006, 08:01 PM   #4 (permalink)
Commander in Chief
I dont know about performances of these cards since I am stuck with an MX 4000
Mobo = 865 (budget buy and easily available, supports 800Mhz FSB and 400 Mhz DDR RAM)
Try finding the 875 for additional performance and stuff...
Harsh J
www.harshj.com
Old 31-05-2006, 10:29 PM   #5 (permalink)
What about 915gav .........................??
cyrux is offline
Old 31-05-2006, 10:49 PM   #6 (permalink)
ymhatre's Avatar
First of all
Hi to QWERTYMANIAC...
NIce to see you here in HAardware section...
Has u said there no mobo for 478 with PCie...soory wrong comment
check this link
http://www.webhallen.com/prod.php?id=41439
only thing i know is tht for this mobo u need 533FSb proci....
no 400FSB will work....
as far as i know only P4 2.4d onwards proci were having 533 FSB...
THE cost of this mobo is 3200 Rs
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 31-05-2006, 11:17 PM   #7 (permalink)
ashfame's Avatar
@ ymhatre
nice find but my cpu fsb is only 133Mhz.
So if i go for mobo of urs then this proci is useless.....hum....
what can i get if i sell my current mobo & P4 2.8Ghz?
i mean how much? any idea....
ashfame is offline
Old 31-05-2006, 11:47 PM   #8 (permalink)
ymhatre's Avatar
a month ago i did the same thing
i selled my 2.4 400 FSB proci and intel 845Gb mobo to only get Rs 5000 from the dealer....
Hope u will know get 5000Rs- 6000Rs....
BUt i did tht a month or two ago... after tht there were prices down...
so u might even get 4.5- 5K
DusT = ME
ymhatre is offline
Old 01-06-2006, 12:07 AM   #9 (permalink)
ashfame's Avatar
is it true that prices will fall when intel new core proci will be launched this year, in aug or sept.??//
ashfame is offline
Old 01-06-2006, 01:25 AM   #10 (permalink)
shovik's Avatar
don't go by guesses. if you wanna good mobo go for MSI's 845PE Max 3 series. I hope you will get everything you want in this motherboard.
shovik is offline
Old 01-06-2006, 09:34 AM   #11 (permalink)
tiblu's Avatar
Why dont u try this mobo Asus P4RD1 MX has onboard ATi x300 xpress 200 chipset and PCIX slot check this out.
http://www.asus.com/products4.aspx?l...71&modelmenu=1
It supports 800 and 533 FSB
tiblu is offline
Old 04-06-2006, 11:42 AM   #12 (permalink)
ashfame's Avatar
Originally Posted by ymhatre
First of all
check this link
my real clock is 133mhz & my effective clock is 533mhz.
can i hav it?
ashfame is offline
Old 04-06-2006, 06:30 PM   #13 (permalink)
ymhatre's Avatar
Yup then u can have it Its 533mhz....
DusT = ME
ymhatre is offline
Old 04-06-2006, 08:31 PM   #14 (permalink)
ashfame's Avatar
r u sure?
or else i would end buying something that is of no use to me.
does only the effective clock is talked about. may be it cpu fsb or ram frequency?
ashfame is offline
