Old 30-05-2006, 08:21 PM   #1 (permalink)
tiblu's Avatar
Question Difference Between DVI & D-Sub
hey guys just thinking of what's the difference between dvi and d-sub i wanted to buy samsung 740 lcd 17'' monitor. but it comes in two types 740N with dsub and 740B comes with dvi which gives better performance.
tiblu is offline
Old 30-05-2006, 09:24 PM   #2 (permalink)
Default Re: Difference Between DVI & D-Sub
DVI gives a better image. The signal is transmitted digitally from the graphics card to the monitor with DVI, while with D-Sub the signal is analog.
If the price difference isn't much, get the monitor with DVI.
drvarunmehta is offline
Old 31-05-2006, 01:46 AM   #3 (permalink)
samrulez's Avatar
D-sub is a analog signal .......DVI is better so get a DVI model......D-sub is mainly used for CRT monitors....MAKE sure ur graphics card has a DVI output..
Sam :D Rulez :lol:
samrulez is offline
