Old 30-05-2006, 09:19 AM   #1 (permalink)
Default Hard disk drive problem........
I got one spare hard disk , when i trie to connect it... it got detected in bios as well as plug & play of windows xp. but no drive is showingin my computer ....what do you think the problem is??
pushkar1986 is offline
Old 30-05-2006, 09:31 AM   #2 (permalink)
champ_rock
champ_rock's Avatar
Default Re: Hard disk drive problem........
maybe u had installed linux sometime, its filesystem is ext3 which is not supported by windows.. therefore the drive will not show..
also, if your drive is new then u should format it first then only it will show up..
Registered Linux user number 400618
champ_rock is offline
Old 30-05-2006, 02:13 PM   #3 (permalink)
is the drive u r reffering to formatted?
avis_gan is offline
