Results 211 to 240 of 1911
Thread: Overheating problems
07-07-2007, 10:30 AM #211Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Re: Overheating problems
Fix it using the four screws and power it either from a molex (from PSU) or from the Mobo.
Originally Posted by sagargv
V.Prem Kumar
07-07-2007, 10:37 AM #212Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
wats a molex ?
07-07-2007, 11:21 AM #213Alpha Geek
- Join Date
- Jun 2007
- Location
- Ichapore,West Bengal
- Posts
- 512
well,branded psus supply additional 4 pin connector(s) specially meant for fans.
its also strongly recommended tht u dont use those connectors to power up nythin else.u can also use mobo pins to power up ur fans.those ll be shown as chassis fans.
07-07-2007, 02:07 PM #214Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
ok . i'll get it today or on monday , any idea of its price ? like , if i have to bargain . let me know how much i shud . . .
07-07-2007, 02:46 PM #215Alpha Geek
- Join Date
- Jan 2007
- Location
- In your hearts
- Posts
- 834
hey when I start my computer then in bios the temprature shown in bios of processor is 45 C and after 5 to 10 minutes it increases to 48to49. It's fan is running at 1900 rpm and it has no dust on it what can be caus of it also there is propr ventilation for cpu.
07-07-2007, 04:58 PM #216Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
^^ wats your proccy ? probobly its configured (by default , mine was too) , to start accelerating fan after temp crosses 50C , no need to worry . But cant tell much without knowing ur procy . .
05-08-2007, 10:38 PM #217
Hi guyz...i jst installed a utility called "speedfan", which monitors the temperatures n fan speeds of the sysstem....after installing the utility, i was surprised as well as confused by wot it showed....hav a look at the attached image of wot it showed....1st of all temme---
1)explain the terms ambient, remote1, remote2,etc...
2) Also i wud like to kno tht the remote2 temp wich s shown as 120c s enuf to smoke my sys, right????
pls elaborate.....thanx_____________________________________________
iPhone 4 16GB___AMD Phenom II 920__GIGABYTE GA-MA78GM__1.5TB HDDs__6GB DDR2__CORSAIR VX550___ZOTAC GTS 450 Amp Ed!!___Samsung Syncmaster B2230__DELL INSP 15
05-08-2007, 11:08 PM #218Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Try installing the latest version of Speedfan 4.31
Originally Posted by sid_sh85
V.Prem Kumar
05-08-2007, 11:26 PM #219
i tried installing the latest version(4.32)....but still thers no change in the temp...pls temme wot s to b done
06-08-2007, 09:49 PM #220Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
@sid_sh85 , ambient is the temp of the sorrounding . . mostly remote2 refers to gpu . .dunno
coming back to my overheating problem on my 8600GT , i wasnt in the house for 15 days and it took me 15 days to get that stupid fan and the vendor to fix it ( LOL ) . .. now while my case is closed , while playing carbon , temp is between 80-85C and peak is 90C . i havent yet tested with the case open . . is this better ? according to him(my vendor ) the prob aint with the g-card . there's a heatsink on the mobo just above the pcie slot which is passing the heat to the g-card . . .he recommends a more roomy cabby .. . i'll get back with the temps when the case is open and i am open to suggestions . . oh and he says the pci slot cooler wont help much coz the g-card is fan cooled and not passive cooled and the super extra heat is due that heat sink . .
and if i may mention , idle temp reduced frm 67C to 57C after putting the exhaust fan . is it better to let the exhaust fan as exhaust or make it to act as inlet . i dont mind keeping the cabby open while playing games . .
ok , i tested carbon with the cabby open . peak 88C , most of the time around 80-85C . .Last edited by sagargv; 06-08-2007 at 09:49 PM. Reason: Automerged Doublepost
06-08-2007, 09:56 PM #221
The total amount of air getting in should be equivalent to the amount of air getting out.So if u have two fans for inlet u should have two fans for outlet.Opening the case and running the pc will most probably disrupt the air flow.
06-08-2007, 10:50 PM #222
but guyz...pls temme how cum my temp is being shown as 120c
06-08-2007, 11:09 PM #223Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Somebody pl elaborate what is meant by temp-1, temp-2, Fan-1,Fan-2 etc in Speedfan. How to decipher it?
V.Prem Kumar
07-08-2007, 09:07 AM #224Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
ok . but my cabby ( mostly i will get a new one next month ) , doesnt have an option to put a inlet fan . . . i will try again with the case closed . but i'm pretty sure it'l yield higher temps..
Originally Posted by Harvik780
the top portion of the PCB of the g-card seems to be very hot . although the gpu fan is spinning , i dont feel the hot air from the sides . will adding a pci slot cooler help ?C2D e7500 @ stock, gigabyte G41 , 2gb ddr2 800Mhz , Seagate 500GB 7200.12 , xfx radeon 4770 , lg dvd-rw , cooler master extreme power plus 500W , altec lansing vs4121 , dell sp2208wfp 22"
07-08-2007, 10:29 PM #225
Hey guyz...i opened my cabby to chk for air flow....jst tell me one thing....my powersupply(450W) is not 24-pin...its lesser...is tht a cause for heating tooo????
08-08-2007, 03:16 AM #226
Did u check the underneath the drives bay.Most ATX cabinets have two vents there for inlet of air.The air is drawn in from underneath.
08-08-2007, 10:07 AM #227Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
nope , there aint a place for inlet .. .best i'll put a pic of my stupid cabby later. thanks..
17-08-2007, 08:04 PM #228
Well my normal pc temp is 43-45C but when i test on pc marks 05 it shot up to 83degree C each core. My xfx 7300gs has a idle temp of 74C. I got 2 fans blowing air directly on the cpu fan. Its the original fan. I need to know the cheapest method of cooling them(500rs max) cause mom will kill me if i ask for more. She already bought me the comp as a gift for 22k.
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
18-08-2007, 01:53 AM #229
83C is too high, it should not cross 60c at full load. Better check if the HSF is seated properly or it maybe that you got that bad IHS. Also idle temp, for 7300GS is too high, those should be your load temps.
Improve the airflow within the cabby (there are numerous guides........just google).---------------------------------------------------
18-08-2007, 09:11 AM #230
@sid_sh85
It cud cause unstability at loads especially when you have got a graphics card. The extra pin mobo connector powers the PCI_E bus.
@Demonkiller
U mentioned that the normal core temps is at 43. Get the reading of the CPU fan at that moment and also the CPU fan reading at 80c.
Probably the fan shud run at max speed when proccy shoots up to 80.
Chech if the fan is covered with dust. Clean the heatsink and fan with a wet earbuds.
Update your mobo firmware. The temp might be wrongly shown by some firware. It happened to my friend. The load CPU temps dropped from 65c to 53c.
Lastly clean all the fans in ur cabby.Last edited by dOm1naTOr; 18-08-2007 at 09:11 AM. Reason: Automerged Doublepost
G3: XPS M1530 |
FZ 16.
18-08-2007, 12:11 PM #231
The fans aint dirty in anyway. Just bought em last month. Barely used the comp 5-6 times since i bought it. And the temps were at stock speeds on everything.
18-08-2007, 12:25 PM #232
Here's my config and the temps-
Asus P5N32-E SLI
XFX geforce 8800gts 640Mb
1 sata 250 gb seagate
1 sata sony aw-s170s DVD writer
Core 2 Duo e6600
2*1gb DDR2 667Mhz in dual Channel
Corsair-HX620W modular power supply
4 80mm Fans 2 intake 2 exhaust
Temps-
Mobo idle-37-39c
Mobo peak load-44c max
Processor idle-49c-51c
Processor peak load-57c Max
Gfx idle-57c avg
Gfx peak load-74c
Other
Overclocking
Memory voltage-2.0V
05-09-2007, 05:58 PM #233
I have a core two duo processor E6300@1.86GHz.I just downloaded speed fan and it shows my cpu temp. to be:
Cpu: 51c
internal temp.: 39c
remote temp: 45c
hd0: 40c
core0: 54c
core1: 52c
I don't know much about the temperatures but there is a burning sign on cpu,core0,and core1 temperatures which has scared me.
Is the temp. normal or I need to do something?
I think the temp. musta been much higher in past months as the climate is much cooler now.Stealing your women and horses since 1843.
05-09-2007, 06:01 PM #234Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
they're OK if u tested with load . too high for idle.
05-09-2007, 06:07 PM #235
hey quadroplex are u harviks bro by any chance?
06-09-2007, 06:52 PM #236
I checked while it was mostly idle just antivirus and firefox.Interestingly I played serious sam 2 for 15 min. to check the rise in temp. but there was none.I am planning to buy a graphic card but I think it will generate even more heat which is not good for my system.I don't know what to do.
06-09-2007, 09:13 PM #237
LOL.
11-09-2007, 12:03 PM #238
The CPU temp that is 51c is shown by the Tcase sensor between the two cores.On core 2 duo it should not cross the 61c mark if its crossing and u are not experiencing any stability issues then its probably showing the wrong temp I too have used Speed fan and it overshoots the safe mark at even stock speeds.The core0 and core1 temps are shown by the TJunction sensors one within each core and if its shooting above 80c u need to be worried any thing less than or equal to 65c at full load is considered safe 70c is warm 80c is throttling(cpu reverts to lower clocks)and 85c is shutdown(If u don't believe then take out the cpu heatsik of a core2duo and watch as it shutsdown).Just download coretemp to monitor the core temps and see if they hit anywhere near the 80c mark on full load.
Originally Posted by The_Devil_Himself
11-09-2007, 02:33 PM #239
^^I have core temp. too and it shows the same temp. shown above.
To check temp. in loaded conditions I played mafia(i love it) at highest settings for about 15 min. and then saw the log created by core temp.
Maximum reached:59c
Normal:55-56c
lowest 52c
Is it ok?Stealing your women and horses since 1843.
12-09-2007, 07:34 AM #240
Download orthos and stress test ur system with it for atleast 1.5 hours.Playing mafia is not going to show the temperature at full load as even the latest games are not able to fully load the core 2 duos.Even lost planet barely manages 50% of total cpu usage(Uses only one cpu and leaves other for windows).
09-01-2012, 09:36 AM
GPU, HDD and CPU overheating.
By debarshi in forum Hardware Q&AReplies: 8Last Post: 26-07-2012, 04:35 AM -
Cpu overheating :\
By TickTock in forum CPU / MotherboardsReplies: 68Last Post: 10-08-2011, 03:21 AM -
CPU overheating!!
By supersaiyan in forum Hardware Q&AReplies: 4Last Post: 27-02-2008, 06:06 PM -
overheating or something else?
By fastc0der in forum Hardware Q&AReplies: 5Last Post: 25-09-2007, 09:17 PM -
Please help regarding CPU overheating ..
By kshiraj in forum CPU / MotherboardsReplies: 5Last Post: 24-10-2004, 01:18 AM
LinkBack URL
About LinkBacks
