Results 181 to 210 of 1911
Thread: Overheating problems
06-06-2007, 10:40 PM #181
Re: Overheating problems
^^well, technically its not
07-06-2007, 10:43 PM #182
Yes it was free!!!
The free version was till 2.2.For all those higher version,u have to pay.
Any New Update BACCILUS?????Last edited by keith_j_snyder2; 07-06-2007 at 10:43 PM. Reason: Automerged Doublepost
08-06-2007, 01:52 AM #183
Re: Help me
My normal CPU temp is betwn 41C-45C. Is this safe 4 my pc to work in this temp.
My pc normal temp is betwn 41 - 47 C . Is this safe temp?Last edited by CA50; 08-06-2007 at 01:52 AM. Reason: Automerged Doublepost
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
08-06-2007, 11:49 AM #184
Ya. It is safe until 50. But u should try to keep it as low as possible.
Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 4GB Transcend 800Mhz | GeCube ATI HD 4850 | 500 GB Western Digital | Corsair VX450W
Dell Studio 1558
08-06-2007, 12:04 PM #185
Thanks but how 2 do it
| Nokia 2700c |
08-06-2007, 12:06 PM #186
Read the march issue of digit
Dell Studio 1558
12-06-2007, 05:18 PM #187Alpha Geek
- Join Date
- Jun 2007
- Location
- Ichapore,West Bengal
- Posts
- 512
hi all.
well i am having some serious overheating probs.
my normal cpu temp. is abt 50C , system temp 45C
nd when i play games, it rises to 60-65C and 55-58C respectively.
plz help me out.
when i open my cabinet,the temperature is less by 6-10 C
wht should be done??
12-06-2007, 07:43 PM #188In The Zone
- Join Date
- Jan 2006
- Location
- Thrissur
- Posts
- 371
Originally Posted by BULLZI
Well; simple...
Fix decent 120mm intake and exhaust fans... 1 intake near the gfx card in the side panel or in the front and 1 exhaust at the rear... 1 intake in the top will also reuce -ve pressure build-up in the cab...iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
12-06-2007, 10:31 PM #189
Also check the airflow of the cabinet & tie those loose cables,those are the real pain in butt!
13-06-2007, 05:09 PM #190Alpha Geek
- Join Date
- Jun 2007
- Location
- Posts
- 512
thnx .
i ll check it out this weekend.
plz response to my query posted in "wht u purchased" thread.
i m planning to buy an antec super lanboy cabinet.
is this a good choice??
ny idea abt the price??in kolkata??Last edited by BULLZI; 13-06-2007 at 05:09 PM. Reason: Automerged Doublepost
13-06-2007, 05:55 PM #191Banned
- Join Date
- Apr 2007
- Location
- delhi
- Posts
- 187
check the chieftec cabinets as well. very good VFM
13-06-2007, 06:15 PM #192
Hi Keith. Thanks for asking buddy. Well the update.... I gave the card back to the dealer and waited for 11 days for it to return. I finally got a replaced card last night and it has the same problem. It is showing the same temperatures. I checked the serial no of the card and it is a different card. It even has the RPTech sticker on it. Now i am really in trouble. I have no idea what i should do next. These temperatures are with the cabinet open with a table fan nearby....
Originally Posted by keith_j_snyder2
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
14-06-2007, 03:11 PM #193Alpha Geek
- Join Date
- Jun 2007
- Location
- Posts
- 512
hi guyz.
i am having a weired problem.
when i m playinf farcry,pop warrior within or splinter cell chaos theory,there s no probs.i am playing in 1440*900 resolutions.
bt when i m going to play CS 1.6,MAFIA ,my machine is hanging completely.
i m having to restart the system.
i hv checked all the temperatures.
CPU:-48C
SYSTEM:-41C
GPU:-60C
wht type of prob is this??
14-06-2007, 10:57 PM #194
i heard that prescotts have good overclockablity and articles in tom's hardware guide term the celeron as their favourite client.......
i have a 2.26 gig cel presscott core
at load it currently works around 60 deg......
is that okay?
also i wanna overclock it to higher speeds.... upto 2.8 ghz.....
can i achieve it with cooling setup costing around 1.5 k?
hey BULLZI..... u dint mention ur gfx card model but most probably it isnt getting adequate cooling .......
add an intake fan to the case somewhere around the card.......
the bottom part of the back of cpu is a good location but it depends on the case u haveLast edited by bikdel; 14-06-2007 at 10:57 PM. Reason: Automerged Doublepost
14-06-2007, 11:48 PM #195In The Zone
- Join Date
- Jan 2006
- Location
- Thrissur
- Posts
- 371
Ther again...
U'd spent a crazy amt on gettin dat stuff frma fraud dealer n u're havin probs now...
Well, I've heard some games dont officially supp widescreen; not sure...
Change the resolutions n see fer urself...iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
15-06-2007, 10:33 AM #196Alpha Geek
- Join Date
- Jun 2007
- Location
- Posts
- 512
yeah,i hv done wrong n now i hv to face the consequences
Originally Posted by gannu_rox
nyway,yesterday night, while playin cs,my machine hanged as usual.
i waited fr some time n then i saw that cs was runnin again with all graphics gone.the screen became multicolored,everything became blackish
is this a problem of graphics card??
@BIKDEL
mine is an XFX 7900GT 256 MB one PCI-ExpressLast edited by BULLZI; 15-06-2007 at 10:33 AM. Reason: Automerged Doublepost
15-06-2007, 09:56 PM #197
Ok now tell me what is ur room tempreature?
15-06-2007, 10:28 PM #198
It must be around 30. Since the outside temperature was 45 degrees last time i checked (on news), room temperature is around 30 degrees. One more thing... I contacted the XFX guys at their website and they told me that the chip is fine till 90 degrees but a little higher than expected. Also asked me not to attemp over clocking in my comp.
15-06-2007, 11:06 PM #199
well ur graphics card is getting heated as i told u BULLZI
check if ur gfx card fan is working or not.........
monitor the temperatures of graphics card........
to do so download FORCEWARE UTILITIES FROM NVIDIA website for ur card
here u can see ur card temperature
its a problem of overheating as ur card works bad only when u start graphix intensive applications like games and not when u use general apps....... isnt it?
if u have warranty replace the card.........
if not then get it checked by a technician.......
06-07-2007, 04:19 PM #200Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
hello ,
sorry i was taking this problem of mine to the wrong area .
I have a p4 presscot HT proccy 3GHz ,intel d101ggc board, 1gb ddr400 , xfx geforce 8600gt . one fan with psu , one with proccy and one with gpu . .
When idling or running net or something thats not graphics intensive my gpu's temp is around 65C . When gaming ,
the temperature if the cabby is closed rises to a peak of 100C and usually maintains in 90-95C . if i open one side of the cabby its max is 90C and usually is between 80-85C .this occurs while playing nfs carbon and most wanted . during fifa07 temp is between 70-75C and while cabby is closed in POP WW i get 80-85 C . I know these temps arent good for my card...
Sabertoothe suggested that there might be something wrong with the card or the mobo(vga controller shorting) . Unfortunately , all my friends have agp based mobo's and i am unable to test which is the culprit.
Further i am suspecting an improper airflow in the cabby as temp reduced by 10c when i kept one side of the cabby open .
Also , how do i know if the fan with the gpu is spinning at the right speed(its spinning ,i saw but i dunno if at right speed) .nTune says that the fan with the gpu is spinning at 675RPM which is very small compared to my proccy's fan speed.but i am not sure if its the right value as it said that fan speed of proccy is 31 thousand !! also it says speed of aux2 is 18rpm .
now , xfx customer care has replied that the card can run at such temps but its not good on a long run .. how long is long run ?? if its 3yrs , i'll forget abt this problem .
how do i decrease temp . .and do i need to ?
Also i wud like to note that the gfx card is not oc'ed .its running at clock speeds..
thank you..
06-07-2007, 05:15 PM #201Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
It seems you are not having any cabinet fans. Try to fit at least one front inlet and one rear exhaust fans, preferably 120mm ones.
Originally Posted by sagargv
V.Prem Kumar
06-07-2007, 06:48 PM #202Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
thanks..
ok . i'll try that . but how can it possibly help ? i kept the cabby open and the temp reduced by 10c . so i add a fan and the temp will reduce only by 5c , right ?
anyways , i will surely try that ..
hey ,
and i can fix only one exhaust fan , i dont see any space to put an inlet fan in the front . mind telling me which fan does wat ? do they take in air or do they push out air ?
thanks.Last edited by sagargv; 06-07-2007 at 06:48 PM. Reason: Automerged Doublepost
06-07-2007, 07:28 PM #203Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Any fan can act as inlet or outlet. The air will flow in the direction of the arrow marked on it. You can fix it either way. If you fix it in the rear, do it so that it blows air out.
Also clean all the components by removing dust, debris etc. and avoid clutter by arranging the cables, wires etc., thus helping better air flow.V.Prem Kumar
06-07-2007, 08:34 PM #204Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
Thanks .
since i can fit a fan only in the rear , shud it act as inlet for air or outlet .
I've checked the cables and cleaned the cabinet.
Also , i wud like to know how much power it consumes . I feel quite embrassed to ask this . how do i fit it ?
06-07-2007, 10:15 PM #205Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Why don't you read the post?
V.Prem Kumar
06-07-2007, 10:56 PM #206Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
oh , sorry i didnt see that . any idea of much power a fan draws ..
thanks.
06-07-2007, 11:02 PM #207Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Just now verified the carton of my Vantec Stealth 80mm fan. It shows 1.2 Watts. But their 92mm fan consumes a lower 0.84 Watts.
V.Prem Kumar
07-07-2007, 12:30 AM #208Alpha Geek
- Join Date
- Jun 2007
- Location
- Posts
- 512
well with my new cabby n psu,no overheating problems rite now
try installing to fans,one to pull air in n one for sucking hot air out.tht ll definitely serve the purpose
07-07-2007, 09:31 AM #209Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
oh , i thought they draw 100's of watts . so it was bugging me whether my psu will be enough .LoL.
Thanks , i'll put it .
hey ,how do i power the fan ?
07-07-2007, 10:29 AM #210In The Zone
- Join Date
- Jan 2006
- Location
- Thrissur
- Posts
- 371
^^^ Frm the PSU of corz....
09-01-2012, 09:36 AM
GPU, HDD and CPU overheating.
By debarshi in forum Hardware Q&AReplies: 8Last Post: 26-07-2012, 04:35 AM -
Cpu overheating :\
By TickTock in forum CPU / MotherboardsReplies: 68Last Post: 10-08-2011, 03:21 AM -
CPU overheating!!
By supersaiyan in forum Hardware Q&AReplies: 4Last Post: 27-02-2008, 06:06 PM -
overheating or something else?
By fastc0der in forum Hardware Q&AReplies: 5Last Post: 25-09-2007, 09:17 PM -
Please help regarding CPU overheating ..
By kshiraj in forum CPU / MotherboardsReplies: 5Last Post: 24-10-2004, 01:18 AM
LinkBack URL
About LinkBacks
