Page 62 of 64 FirstFirst ... 12 42 52 53 54 55 56 57 58 59 60 61 62 63 64 LastLast
Results 1,831 to 1,860 of 1911
  1. #1831
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Default Re: Overheating problems
    My cabinet has 2*120mm LED fans at side, 1 LED at front and 1 at back. No other fan options available. PSU is top mounted.
    So, is the fan placement correct? Or do I need to make any changes?
    Check here
    My Blog :D
  2. #1832
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    ^^ what's RPM of those fans ?? if you have a 2K RPM fan place it at rear as exhaust, mount the side panel fans and the front fan as Intake.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  3. #1833
    Jan 2011
    Bhubaneswar
    No RPM details mentioned. Both the side fans were actually placed as intake but just a few hours ago after a bit of google I decided to use the top side fan as exhaust.
    So, should I keep the fan as exhaust or should I revert it back to intake?
    And except the rear one, the rest three are LED fans.
    I think you didnt check that image file!
    Check here
    My Blog :D
  4. #1834
    damnbadman666 damngoodman999's Avatar
    Nov 2008
    Coimbatore
    Quote Originally Posted by topgear View Post
    ^^ After a long time I'm seeing you posting
    no keep those rear fans as exhaust and if possible ( with a little nodding or something like that ) try to add a front or side panel fan as intake.
    Thanks Top , yeah went thru hard time . Its good to be back "i'll be your guest from now"
    DEATH IS OUR BIRTH RIGHT - SO Y FEAR DEATH ???
  5. #1835
    Jul 2006
    Geek's Heaven
    ^^ Great to see you back and edit your siggy - no smile icons are visible.
    @ saswat23 - I've checked the image file but where's on image it's shown that those fans are LED fans ? Aviator comes with 1k RPM fans - it would be better if you add a CM 120 mm 2K RPM LED fan ( available on FK ) at rear as exhaust and use all the side panel and front fan as intake only.
    Who Dares Wins
    Avenging Angel !
  6. #1836
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Replace the front intake with a very goof fan, like CM 90cfm 2K rpm fan.
    Use the other 3 slots as exhaust with the existing fan. This will create negative air pressure which is good for the cabinet you have (i.e. no top exhaust slot).
    Inactive in TDF.
  7. #1837
    Wise Old Owl Myth's Avatar
    Jun 2012
    Bhubaneswar / Kolkata
    I needed to sell a processor( + heatsink) so I cleaned up the thermal paste from both items to post the pics here. Now the buyer wants to check ( bios readings ) once before taking delivery. Unfortunately, both of us are out of thermal paste at the moment.
    Question: Can the processor be run (max 2-3 mins) with the heatsink but no thermal paste on either surface ?
    Intel i7 2600k, Asus P8Z77-M Pro, Sapphire HD 7950 VaporX with Boost | Palit 9600GT, Corsair TX650v2, CM Hyper 212 Evo(push-pull), CM Elite 430, Altec Lansing ATP3 2.1, Samsung Syncmaster 2033, Corsair 2x2GB, Seagate 1TB + WD 1TB Black + Maxtor 300GB, Win7 Ultimatex64, CPU-Z , GPU-Z
    Need Help :
    * Looking to purchase Noctua NH-U12P SE2 :(
  8. #1838
    Jan 2011
    Bhubaneswar
    Why don't you use those cheap Rs.20 wala TIM for that time.
    You can use your proccy w/o TIM but soon your system will shutdown due to overheating.
    Check here
    My Blog :D
  9. #1839
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by Myth View Post
    NO, use cheap tim from local stores, or you could use toothpaste(colgate, normal), I won't be held responsible for any damage.
    toothpaste tim.
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  10. #1840
    Jun 2012
    Thanks for the reply, Yes/No was all that was required.
    The toothpaste tim is a first time I have heard of it
    Need Help :
  11. #1841
    Jul 2006
    Geek's Heaven
    ^^ you can run the cpu without TiM and if the contacts are really good then it will run fine and won't shutdown due to overgeating - I've run P4 cpu without TiM a long time back.
    Who Dares Wins
    Avenging Angel !
  12. #1842
    Jun 2012
    It just has to run for 2 mins so that the buyer can check the stats in the bios.
    I will try advise him not to try this, but he insists, I'll do a quick run
    Need Help :
  13. #1843
    Aug 2011
    Kolkata
    When running for short time, use toothpaste.
    Inactive in TDF.
  14. #1844
    In The Zone aloodum's Avatar
    Feb 2011
    Aloo nation
    Quote Originally Posted by d6bmg View Post
    Firstly , Is it too hard to ask the local comp shop/elect repair shop for a 10 buck satchet?It's not a novelty product and found easily everywhere.
    tooth paste? Highly un reccomended as opinions are highly divided.More than anything im concerned about the etching/corrosive nature of most fluride based toothpaste(s) on the heatspreader..
    Read on more here:
    Toothpaste+vaseline Adventures!!! - Overclockers Forums
    Thermal transfer compound comparison
    You got your peanutbutter on my cpu! You got your cpu in my peanut - OverclockersClub Forums
  15. #1845
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by aloodum View Post
    Read on more here:
    Its good for one run, ONE run only, as he said he needed to boot it once for 2 mins, it won't corrode anything by then(colgate normal white, no fluidized gel stuff).
  16. #1846
    Jul 2006
    Geek's Heaven
    for short time testing thre's no need for any sort of paste ( IMO ) - just today ran my 955BE ( 125W ) using a Athlon cpu without any paste for testing ( 5-6 mins ) and the max temp I got was 47c under bios screen.
    Who Dares Wins
    Avenging Angel !
  17. #1847
    Aug 2011
    Kolkata
    Take my advice, and don't use it in that way unless you are using a binned CPU (which you are not). Its risky. CPU haven't got burned ok. You can take it as your good luck.
    Inactive in TDF.
  18. #1848
    Jul 2006
    Geek's Heaven
    ^^ I won't use it in that way -- cpu is back again under the mighty weight of Hyper 212
    Who Dares Wins
    Avenging Angel !
  19. #1849
    Aug 2012
    Hello everyone...
    I bought two cabinet fans.. one coolermaster 1800RPM and another cheap one 1500 RPM.
    There are two places where I can place them, one is below the PSU ( above the VGA port and PS/2 ports ) and one on the side wall of the cabinet ( parallel to the CPU fan and heatsink). Where do I place these fans and how do I place them(intake or exhaust ).?
    Please suggest a good way because my CPU is always above 75C on no load...
    BTW I'm replacing the thermal paste also(coolermaster).
    Thank you..
    If you guys need any pics please let me know.
  20. #1850
    Jul 2006
    Geek's Heaven
    @ dhruv.arora25 -
    size of the fan mounting holes of the cabinet - 80 / 120 mm ?
    size of the CM 1800 RPM and 1500 RPM local fan ?
    Do your cabinet has any front intake fan ?
    Which CPU do you have ? ( Post a few pic of the cabby if possible )
    put the 1.8k RPM fan as inatke on the side panel and the 1.5K RPM fan at back as exhaust.
    Who Dares Wins
    Avenging Angel !
  21. #1851
    Aug 2012
    I have a machine with following configuration:
    Intel i3 2100, Intel DH67BL mobo,EVM 2 GB RAM, Seagate 500GB HDD (ST500DM002),LG optical Drive,Asus 5450 (1 GB) graphics card, Samsung 22" full HD monitor and iBall Grandeur cabinet with PSU. Running Windows 7 (32 bit).
    My problem is that the machine got restarted suddenly on 2-3 occasions while in use. I suspect some overheating. I am giving below the snapshot of HW monitor immediately after the restart. I dont understand all the details, so pls. guide me what are the temperature required to be monitored for overheating problem.
    What should I doif theres an overheating?
    My case has one fan at the rear and vent holes on side panel
    The grafix card is silent one with only heat sink and no fan.
  22. #1852
    Jul 2006
    Geek's Heaven
    except from the 2nd Auxtin temp, cputin temp and +12v reading every other values looks normal.
    Now the 2nd auxtin temp could be wrong and so is +12v reading but the cputin temp without any load reaching 69c indicates there may be cpu overheating issue - use IBT load test for 10 mins and post a screenshot of of HWmonitor. Also check the +12v reading from system bios and make sure your ram module has no issue by using memtest86+ app.
    Who Dares Wins
    Avenging Angel !
  23. #1853
    Wise Old Owl Revolution's Avatar
    Mar 2008
    East India Company
    What is the most accurate to monitor Intel C2D CPU Temp ?
    Is it CoreTemp or RealTemp or Everest HE or any other ?
    At the same time all above 3 application showing CPU Temp of 40C,44C & 41C respectively.
  24. #1854
    Otaku debarshi's Avatar
    Mar 2011
    WB
    Default Re: Hardware Price Check and Buying Advice Thread (Kolkata)
    Could it be that my Proccessor is heating to 75 at idle due to my smps, or do i just need to change my stock cooler and re tim it........
    "People think focus means saying 'YES' to the thing you've got to focus on. But that's not what it means at all. It means saying 'NO' to the hundred other good ideas that there are"
    MyAnimeList
  25. #1855
    Alpha Geek avichandana20000's Avatar
    Jan 2010
    India, City of Joy
    ^^ enter BIOS and recheck the temp. If it is still high please clean your heatsink,fan and re-tim it. BTW is cpu fan spinning?
    NZXT PHANTOM WHITE+3INTAKE 2EXHST|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 1GB DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1+1 TB|LOGITECH G110|APC 650 VA|+WD MY PASSPORT 3.0 1 TB
  26. #1856
    Jul 2006
    Geek's Heaven
    @ debarshi - first try to re-tim using some good TiM like Noctua NT-H1 or DeepCool Z5.
    Who Dares Wins
    Avenging Angel !
  27. #1857
    Mar 2008
    East India Company
    Quote Originally Posted by Revolution View Post
    Guys what application u all using to monitor ur HW Temp ?
  28. #1858
    Feb 2011
    Aloo nation
    ^^ coreTemp/realtemp are pretty much the good guys out there..Though you may have cases where these two or other hw monitoring apps shows different readings!!! Reason being software monitoring tools give figures based on algorithms to calculate temp. And this algo differs for each monitoring s/w.
    The easiest way to figure out the wrong app is a look at the TJmax figures for your processor, mind you it will depend on the specific cpu revision ...the one that shows the wrong TJmax figures is to be chucked
  29. #1859
    Mar 2008
    East India Company
    Thanks for ur reply!
    What should be TJmax of Intel Dual Core E2180 and Intel C2D E4500 ?
  30. #1860
    Mar 2011
    WB
    I did re tim my CPU 1 month back using CM essentials E2. No substantial improvement in temperature.
    Quote Originally Posted by avichandana20000 View Post
    I quoted the temperature from the bios itself. In speedfan it shows 80 all the time. I recently cleaned my whole pc including heatsink. And yes, the cpu fan is spinning at 1800-2000rpm.
    What could be my next step...........
    BTW, my processor is Intel Pentium D CPU 2.80GHz
    MyAnimeList
  1. GPU, HDD and CPU overheating.
    By debarshi in forum Hardware Q&A
    Last Post: 26-07-2012, 04:35 AM
  2. Cpu overheating :\
    By TickTock in forum CPU / Motherboards
    Last Post: 10-08-2011, 03:21 AM
  3. CPU overheating!!
    By supersaiyan in forum Hardware Q&A
    Last Post: 27-02-2008, 06:06 PM
  4. overheating or something else?
    By fastc0der in forum Hardware Q&A
    Last Post: 25-09-2007, 09:17 PM
  5. Please help regarding CPU overheating ..
    By kshiraj in forum CPU / Motherboards
    Last Post: 24-10-2004, 01:18 AM
