Results 151 to 180 of 1909
Thread: Overheating problems
16-05-2007, 09:00 AM #151
Re: Overheating problems
guys .. i own AMD 3600+, with asus M2NPVVM mobo and zebronics cabby.. my processer runs at 45-59 C depending on the load when the local temp is around 32-40 C. is it okay ???????
16-05-2007, 01:07 PM #152
anything in the range of 50-55C at load is ok ,above that is worrisome.
Originally Posted by harryneopotter
16-05-2007, 05:20 PM #153
well mine is running @ 74 ... which is quite high ... any method to reduce it ? Its a P4 3.2 with Intel 915 mbrd .. have a basic simple cabinet and recently im keeping the case side doors open .. still the high temp ..... I got a Asus Starice cooler http://www.viperlair.com/reviews/coo...ks/asus/stice/
but my vendor is not willing to put it in saying that it might break my mbrd !!! Can this happen ? The CPU cooler is clean and is running right ..... still the high temp ... can there be anything wrong in my Processor ???
As for advice people even told me to go and buy an AC !!! Do the new core 2 duo / quad have these heating probs ?a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
16-05-2007, 05:49 PM #154
What is the max allowable temp for a motherboard ?
What is the max allowable temp for a motherboard ?Last edited by GeekyBoy; 16-05-2007 at 05:49 PM. Reason: Automerged Doublepost
16-05-2007, 09:55 PM #155
Well have u ever saw the old control panel of nVidia?Can't say about the new one but the old one says the max. temp. 125degrees,but thats crap.
The max. temp should be not more than 60 degrees & u can hardly see this temperature except in the old X1800XTX.I still remember there was a GPU cooler roundup for the ATi X1800XTX which was a burning rod at 80degrees & the best cooler tunes it to 63 degrees.
Same should be for every single hardware.AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts.
23-05-2007, 08:55 AM #156Apprentice
- Join Date
- Aug 2005
- Location
- NLU Jodhpur/ Lucknow
- Posts
- 97
tell me why to worry so much abt cooling... i understand heat can fire off CPUs...
but why to keep cabinets closed.... i have 2 120 mm n one 80 mm fan in my cabinet n temp for amd 3000+ remains at around 44 degree while playin game n drops to 41-42 degrees when i open the cabinet... thats without overcloacking...
so why cant we just leave it open cos most of us are hardware junkies n have to take out Hdds to share with frnds every now n then... so why worry abt it.... as someone said... open it up n keep a small car fan near it.... in my case it did affect a lot... even while playing call of duty 2 with 4xAA n 4x AF the temp didn't go aboce 40 degrees....
23-05-2007, 01:10 PM #157
Single cores is ok but you have no idea what happens to Dual Cores once they are OC'ed
Originally Posted by samanvya_ad
OT : what sharing data got to do with being a hardware junkie ?
23-05-2007, 02:51 PM #158Banned
- Join Date
- Apr 2007
- Location
- delhi
- Posts
- 187
@darklord saw ur water cooling kit. nice work dude. which cabinet r u using?
23-05-2007, 04:07 PM #159
I am using Zebronics Jamaica Chassis.VIP ZB-01 is also the same thing.I mean the interiors,front bezel is different.
Originally Posted by kooabs03
23-05-2007, 04:26 PM #160Apprentice
- Join Date
- Aug 2005
- Location
- Posts
- 97
why... what happens... they go beyond 100 degrees or what....
Originally Posted by darklord
i bet they will remain cool by this opening the Cabinet method until u insanely overclock them...
and as far as i know generally we dont overclock our Pcs more than 30% of its actual speed...
by this i meant that generally our cabinets remain open for some or other reason n sharing is one such reason....
so when it remains open then y not to use it for cooling... i will definately not spend 10-12 grands on a water cooling kit...
instead will get an ac that cools the computer as well as me..... N with that Ac in room i will open the cabinet n face it towards the open box... cool cool coool PC
now whats the harm in opening the box......Last edited by samanvya_ad; 23-05-2007 at 04:26 PM. Reason: Automerged Doublepost
26-05-2007, 10:40 PM #161
Hi I have an 8500GT card from XFX. this card always stays around 70 to 80 degree celsius. It's fan speed always remains at 675rpm irrespective of the temperature. Please help.
I measered the temperature using the nTune utility. When i used speed fan, it showed me the following temperatures:
System 47*
CPU 51*
AUX 48*
HD0 44*
(The nTune software shows my GPU at 70* right now but it can easily go upto 80*C)
What is AUX here? and why is it not showing my GPU temperature?
Currently i have kept my cabinet open for better ventillation as i don have any fans in my cabinet.Last edited by baccilus; 26-05-2007 at 11:03 PM.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
26-05-2007, 10:57 PM #162Right Off the Assembly Line
- Join Date
- May 2007
- Posts
- 10
hi i have gor c2d E6700 processor & intel 965wh board . my processor shows temperature in idle state at 48c & when i play games like nfsug 2 it shoots to 60c & even the game is closed down a no. of times. i m not having original fan of this processor. also i am using a simple cabinet with 2 80mm fan.
my fan rpm usually remain at 1018
i have also selected aggressive setting in bios for better but no benefit
Please help me ,suggest any good cooling solution for c2d which is available easily.
26-05-2007, 11:17 PM #163Alpha Geek
- Join Date
- Jan 2007
- Location
- In your hearts
- Posts
- 834
So you shold have fans for your cabinet.
27-05-2007, 08:11 AM #164
My cabinet is already open. And all other components are running ok. Can't I get a better fan for the graphic card? I think it will be a better solution. But where to get it from? How much will it cost? Is it even possible to put another fan in place of the original one in this card? It is directly powered from the PCIe slot. It has no wires or anything.
BTW, is the reported temperature always correct? Because when i keep my hand really close to the GPU fan, the air is not warm at all. And it is still showing 70*C temperature. Or it may mean that the fan is not dissipating the heat properly as it is not fitted properly. But how can that be, since it came prefitted with the card.Appreciate me now and avoid the rush!!
27-05-2007, 08:13 PM #165
What fan are u using for your processor?
Originally Posted by lavi87
Well u can get a quality cooling solution for your graphics card but u will loose your warranty in that case.U can get few cooling solutions from Cooler Master or Thermaltake.If nothing is happening ,i say go for an RMA without loosing the warranty!
Originally Posted by baccilus
Last edited by keith_j_snyder2; 27-05-2007 at 08:14 PM. Reason: Automerged Doublepost
27-05-2007, 10:55 PM #166
Tell me more about RMA please. Where can i get it from and at what cost? By the way, should i really worry too much about this problem since my system never hangs or anything?
27-05-2007, 11:54 PM #167
Return Materials Authorization.
This is when u have a faulty product & or if u are not satisfied with the product,then u return it to the place from where u have bought it & the company reimburse the person who returned the stuff.
Sometimes we call it utilizing the warranty but RMA is for early stage & warranty is what u get.
So ask the dealer if he can return it & give u another card beacuse its faulty.
Dude the temp. plays a vital role in performance.If temp is hig then the performance is low & vice versa.
So its really necessary that u have your stuff in absolute working condition.
Although it is a high temp. but not that high but why taking risk?This might be just a start.
Do these things before going for a change.
1.Use any other temp. monitor for ur system & also download all the latest drivers including nTune.
28-05-2007, 05:47 PM #168
Thanks Keith. I have the latest driver and nTune. Can I directly return to Rashi? Actually the dealer i got it from turned out to be a pest. Right now nTune is the only software capable of reading it's temperature.
And what are the chances that the temperature is not being read correctly? The air being thrown out by the GPU fan is not warm at all.
By the way i also got a cabinet with 3-4 fans and one directly beneath the graphic card, Didn't help much.Appreciate me now and avoid the rush!!
28-05-2007, 07:51 PM #169
There is no need to talk to rashi periphrals.Do u have the Bill for the Card?
If yes u can sue him anytime.Where is your location & who is the dealer?What is his address & contact no.?
U can also use various type of softwares that shows the temp. Like nTune,MBM,Everest,Speedfan etc....
Try them first before u take any step!AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts.
29-05-2007, 10:01 PM #170
Thanks buddy. I tried rivertuner and it shows 70* too. Will try more software and then talk to that dealer and see how he reacts.
Ok, i tried Rivatuner and while playing games the temperature is going upto 87* .
Now in case i give it back to the dealer to get it repaired, should i get something signed or anything from him. I mean i should have some proof that i have given the card back to him for repair.
Koi to kuchh jawab do yaarLast edited by baccilus; 29-05-2007 at 10:01 PM. Reason: Automerged Doublepost
30-05-2007, 12:55 AM #171
Actually it all depend on the dealer that how trustworthy is him!
If u think that u don't need anything & u have full trust on him then u won't require anything but if u are not sure about him then give a reason that u need something like a slip that someone else can also get on ur behalf because u will be out of town.....something like that!AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts.
30-05-2007, 09:25 AM #172
I don't have much of a trust on him but i also know he won't fall for that. Actually he is not the only one like that. All of the dealers i have come across in Chandigarh are like that or worse. They are also chronically allergic to giving bills on what they sell. Will go to him today and see how he reacts.
30-05-2007, 04:36 PM #173
I installed speed fan. It shows 3 temperatures
TEMP CHIP
Temp1: Winbond W83627HF
Temp2: -do-
Temp3: -do-
Temp4: HD0
Here is the screenshot.
I know the last temp is of Hard Disk. But what are the others? Just tell me what are these temperatures and what is wrong with them?Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 4GB Transcend 800Mhz | GeCube ATI HD 4850 | 500 GB Western Digital | Corsair VX450W
Dell Studio 1558
31-05-2007, 10:50 PM #174
Can't tell u exactly but the 2 temp. in the middle with the flame in front of it are critical.
U must be having read me file with the Speedfan or else see the config. file.I haven't use it before but these are the 2 possibilities to find out.I am using EVEREST Ultimate edition.Try it once.
Don't rely on a single software,use multiple of them.
& please do an update also buddy!AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts.
01-06-2007, 04:21 PM #175
This came with digit. And one thing is that the temp 3 is always at 64 or 65. Even when i just boot the pc and check the temp first it doesn't go up or down.
Dell Studio 1558
01-06-2007, 08:23 PM #176Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
I also have always been confused by Temp-1,2 etc. in Speedfan. Hope somebody will elaborate.
V.Prem Kumar
01-06-2007, 09:10 PM #177
@janitha what are the temperatures on ur pc?
Dell Studio 1558
01-06-2007, 10:16 PM #178Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
Temp1:36
Originally Posted by Shloeb
Temp2:39
Temp3:26
HD0: 40
Temp1:40
Core : 35
Ther are two Temp1s with diff values and most surprisingly Temp3 is 26 when the room temp is 30.5!V.Prem Kumar
06-06-2007, 12:13 AM #179
the best software to measure temp is lavalys everest. it quite simple and not at all confusing. it gives temp of all components as well as speed of fans etc
06-06-2007, 04:55 PM #180Wise Old Owl
- Join Date
- Apr 2005
- Location
- Kollam, Kerala
- Posts
- 1,801
But is it free?
Originally Posted by xbonez
V.Prem Kumar
09-01-2012, 09:36 AM
GPU, HDD and CPU overheating.
By debarshi in forum Hardware Q&AReplies: 8Last Post: 26-07-2012, 04:35 AM -
Cpu overheating :\
By TickTock in forum CPU / MotherboardsReplies: 68Last Post: 10-08-2011, 03:21 AM -
CPU overheating!!
By supersaiyan in forum Hardware Q&AReplies: 4Last Post: 27-02-2008, 06:06 PM -
overheating or something else?
By fastc0der in forum Hardware Q&AReplies: 5Last Post: 25-09-2007, 09:17 PM -
Please help regarding CPU overheating ..
By kshiraj in forum CPU / MotherboardsReplies: 5Last Post: 24-10-2004, 01:18 AM
LinkBack URL
About LinkBacks
