Page 17 of 64 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 37 ... LastLast
Results 481 to 510 of 1911
  1. #481
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Default Re: Overheating problems
    Quote Originally Posted by sub1zero View Post
    I have a P4 2.6 GHZ, 1GB DDR(transcend) RAM. I had overheating problem a couple of months ago so I installed another fan(currently have 2) which rectified the problem. But again this nagging problem has cropped up. What do I do now?! Can overheating be caused by RAM malfunction or corruption of BIOS?
    May be your CPU Cooler grills are clogged with dust, happened in my old machine, needs serious cleaning.
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  2. #482
    Oct 2008
    These cooler grills you talk about. How exactly do I identify them? My board is not too dusty. Would a simple brush suffice to clean? Have NO IDEA where to get compressed air etc
  3. #483
    Aug 2008
    Hyderabad, India
    Your CPU Cooler(Or Heatsink) has two parts, on the top there is a fan and in the bottom there should be a grill like structure. Dust accumulates there in the gaps, try looking closely.
  4. #484
    ace
    ace is offline
    Sep 2006
    Quote Originally Posted by tkin View Post
    Download this software and view the temperature, only it shows the right temp values for your proccy:http://www.techpowerup.com/realtemp/
    If beyond 45c, remove heatsink, clean and re-apply thermal compound and re-attach the heatsink, its not attached properly.
    You may need the help of a technician.
    @tkin ... thnx
    temp are same (51-53)idle...
    also i hav done the reseating many times.... no change...
    i hav applied thermal compound...
    i need advice on a gud cpu cooler... within 2k (max) for my proc q6600.
    also my hdd temp is 35...
    plz give all options with price in mumbai...
  5. #485
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by ace View Post
    @tkin ... thnx
    Look here;http://techshop.in/store/index.php?cPath=320_243_244
    Since I don't live in Mumbai I can't help you there, post your queries in this thread;Latest Hardware Prices & Quotes..!!
    P.S-Your HDD temp is fine, just the proccy seems a tad high.
  6. #486
    Broken In ironfreak's Avatar
    Dec 2007
    which is best Thermal paste/compound (whatever...) ???
    "The medium is the mess(ed) age" !
  7. #487
    Rising ApocalypsE keith_j_snyder2's Avatar
    Dec 2006
    Quote Originally Posted by ironfreak View Post
    The one which has diamonds or silver in it!
    As far as the pocket allows & pretty reasonably priced, Arctic Silver MX-2!
  8. #488
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by keith_j_snyder2 View Post
    They are different products by different manufacturers.
    AS5 contains silver
    http://www.arcticsilver.com/as5.htm
    MX-2 is considered better and has no breaking in period, conductivity and capacitance.
    http://www.arctic-cooling.com/further_prod2.php?idx=140
    V.Prem Kumar
  9. #489
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    I bought coolermaster thermal pate for Rs. 350. Which is running my pentium D 925 cpu @ 3.2 ( oced from 3 ghz to 3.2) ghz only 22C and on load 32 C with stock cooling.
    Before applying the paste the proc was running - idle 32C & onload 42-45C.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  10. #490
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by topgear View Post
    Your ambient temperature should be less than 22C. Otherwise the reading is incorrect.
    V.Prem Kumar
  11. #491
    Jul 2006
    Geek's Heaven
    The reading is not incorrect and yes ofcourse in the winter season the ambient temp is about 16c in here at night & 21c at day ( kolkata ).
    Lets see what happens in summer
    Who Dares Wins
    Avenging Angel !
  12. #492
    Apr 2005
    Kollam, Kerala
    U are lucky. Here it is already damn hot during daytime!
    V.Prem Kumar
  13. #493
    Jul 2006
    Geek's Heaven
    Ya. Thanks buddy.
    But in summer season The ambient temp reach as high as 40-42C
    Who Dares Wins
    Avenging Angel !
  14. #494
    Boom Boom Boom cooldudie3's Avatar
    Jul 2007
    MACHEAVEN
    I just posted a thread about my Fujitsu Lifebook S6240's fan dying. Now it's heating up really fast and I am afraid something will fry.
    Fan Error on Fujitsu Lifebook S6240
    I'm back! Gimme a hugggggg... :D
  15. #495
    Right Off the Assembly Line Gaurav_rip's Avatar
    Nov 2006
    Jaipur,India
    Help Me!!!!
    I ve a HP dv1135ee Laptop
    Its specs r ...
    CPU: Intel Core 2 Duo(Centrino 2) P8400@2.26Ghz
    RAM: 3Gb
    GPU: nVidia 9600M GT
    It gives a gr8 gamin experience but at a price...
    It gets really heated up specially near the ventillations even when kept on a even surface in a fully air conditioned room. I dont ve a soft to measure the machine or GPU temp. so i dunno the exact temp and alll..
    Can u plz suggest some sort of laptop cooler or somethin..
    I live in Jaipur so if somethin which can be available locally would be gr8
    Else also somethin which is really effective but not very heavy on d pocket...
    dO v aLwaYs neeD to saY sOMethIn???
    Proud owner of ....
    Laptop Model:HP dv5 1135ee
    Processor: Intel Core 2 Duo (Centrino 2 ) P8400@2.26 Ghz
    Ram:3 GB
    GPU: nVidia 9600M GT ( 512 MB dedicated)
  16. #496
    Jul 2006
    Geek's Heaven
    Try coolermaster or Belkin laptop coolers. The price range is between Rs. 1500-2500. They should be localy available.
    To measure the temp download everest ( paid ) or pcwizard ( free )
    Merry Christmas
    Who Dares Wins
    Avenging Angel !
  17. #497
    In The Gaming Heaven tanmoy_Siliguri's Avatar
    Sep 2008
    @ topgear
    If u r from Kolkata..then can u give the shop name,address & ph no from which u have bought Coolermaster thermalpaste.
    Also any guys from Kolkata know a shop that have Coolermaster thermalpaste ready.
  18. #498
    Jul 2006
    Geek's Heaven
    Hi. I'm from there. I bought it from :
    M.D Computers 16/1, GC Avenue.
    Near Exide Showroom. Opposite Inox a Small Shop
    Who Dares Wins
    Avenging Angel !
  19. #499
    Sep 2008
    @ topgear
    I am from Siliguri...next week I have to go Kolkata due to some work..so can u give me the shop's ph number & direction from Sealdah?Also what is the full name of the shop?
  20. #500
    In The Zone channabasanna's Avatar
    Jan 2007
    Bangalore
    Hi All,
    Last Night i removed one of the old 80mm fans which i had attached to my Elite 332 Cabinet, this fan was directly blowing (intake) to the Graphics Card, from few days it etarted making a hell lot of noise when my pc is running. After removing the Fan i could see the idle graphics card temperature be 50C, after Playing Prince of Persia i saw its temperature as 62C, when the fan was there idle temp used to be 43-45 and after playing Games it used to be 55-56. Is this temperature of Graphics Card fine after removing the fan.
    C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
  21. #501
    Jul 2006
    Geek's Heaven
    Quote Originally Posted by tanmoy_Siliguri View Post
    @ topgear
    M.D. Computer
    16/1 Ganesh Chandra Avenue,
    Kolkata - 700013 (Near Exide Showroom)
    Ph: 2234-6274
    2253-7133
    9830243212
    Contact persons: Mr.Pankaj & Pradeep
    From Sealdah - Hire a taxi. Tell Him you want to go to C.R. Avenue - Yogayog Bhavan or Airlines Building. Get Down There & Follow The instructions on the Image. Hope this helps.
    http://www.harepix.com/images/687739411.jpg
    Quote Originally Posted by channabasanna View Post
    Hi All,
    The temparature is just fine & is in the safe limit.
    Though it's better if the temp stays even lower. Why don't you a attach a new fan.
    Who Dares Wins
    Avenging Angel !
  22. #502
    Aug 2008
    Hyderabad, India
    Hi All,
    Its well within safety limit, but lower is better, a 80mm fan costs 40/-, get a new one.
  23. #503
    Jan 2007
    Bangalore
    The one is removed is a old one which had cost me Rs50/- I have a other 80mm fan which i had removed from my old Mercury Kobian cabinet, will try using that. Do we get any Vibration dampener to attach to the fan, so that to avoid the vibrations, i will connect it to the grill which is present to the side of the cabinet, i mean the grill below the chimney of the side panel.
  24. #504
    Aug 2008
    Hyderabad, India
    I don't think something like that exists, if the fan vibrates too much you can buy a new one or try attatching rubber washers.
  25. #505
    Jan 2007
    Bangalore
    While going through eBay i found one of this, http://cgi.ebay.in/Vantec-Fan-Vibrat...|39:1|240:1318 . I need to know is this available in most of the stores. If so i dont wanna spend 250 Rs for just that rubber kit.
  26. #506
    Will Power TheLetterD's Avatar
    Aug 2008
    Hey how hot can A ZOTAC 9500GT,4850HD GO?
  27. #507
    Feb 2009
    Hey I am suffering from Serous Overheat Issues. on my Storage PC
    My PC P4[515]-90nm 2.93Ghz
    My Core Temp reaches 70C at normal workload OMG
    Where as My other Component have Temp of 35C~40C like HDD and GPU.
    I don't Use this PC to work , just use it for storage. But the fan Noise is irritating.
    and After reaching 70C There is am major slowdown in performance.
    Where as my other PC with C2D has a Core temp of 40C max- I play games and do all the stuff in this PC and even after 4 Days of Continuous work the Temp never Reaches above 45C.
    Does this Indicate any problem with My storage PC?
    Do I need to Change the Fans? cause they seem to work fine at 4k+RPM
    I have a 80mm Fan at the Exhaust and a large CPU fan which Runs at very high RPm[Forgot Speed].
    Please Suggest What do i do.
    Thanks
  28. #508
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by ayuboy View Post
    Thanks
    How do you measure the temperatures?
    Remove HSF, clean its contact surface and also processor surface with Isopropyl Alcohol. Apply grain size of MX-2 or AS5 thermal paste on the centre of processor and properly reinstall HSF. Ensure that the cabinet is well ventilated with at least one inlet and two more outlet fans.
    V.Prem Kumar
  29. #509
    Feb 2009
    Talking Re: Overheating problems
    I measure my core Temp and RPM of my Fans from Speedfan Software
    Thanks, I'll Try that.
  30. #510
    Feb 2009
    Yes I fixed everything and now it works fine.
    No more noise and CPU temp is 42C normal load and 50C high load.
  1. GPU, HDD and CPU overheating.
    By debarshi in forum Hardware Q&A
    Last Post: 26-07-2012, 04:35 AM
  2. Cpu overheating :\
    By TickTock in forum CPU / Motherboards
    Last Post: 10-08-2011, 03:21 AM
  3. CPU overheating!!
    By supersaiyan in forum Hardware Q&A
    Last Post: 27-02-2008, 06:06 PM
  4. overheating or something else?
    By fastc0der in forum Hardware Q&A
    Last Post: 25-09-2007, 09:17 PM
  5. Please help regarding CPU overheating ..
    By kshiraj in forum CPU / Motherboards
    Last Post: 24-10-2004, 01:18 AM
