Page 16 of 64 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 36 ... LastLast
Results 451 to 480 of 1911
  1. #451
    Rising ApocalypsE keith_j_snyder2's Avatar
    Dec 2006
    Default Re: Overheating problems
    Quote Originally Posted by mAYHEM View Post
    Can anyone suggest a Northbridge sink for Gigabyte GA-MA78GM-S2H
    Akasa AK-210 Chipset Cooler
    Enzotech SLF-1
    Zalman ZM-NBF47
    Nexus NHP-2200
    Thermaltake Extreme Spirit II
    Evercool Serpent
    The list goes on but these r few that should do the job!
  2. #452
    I M A *STAR* saqib_khan's Avatar
    Nov 2007
    Planet Earth
    Hi,
    My friend has AMD Athlon 64 X2 4800+ processor , it shows cpu temp of 50 degree c, is this temp ok? The mobo is of asus, and from there i m reporting this temp. This temp comes after starting the pc for the first time.
    Blogging at:
    Technostarry
  3. #453
    Dec 2006
    Quote Originally Posted by saqib_khan View Post
    Hi,
    Is it at load or idle temp.?
    Whatever it will be if it is at load then its the best & if it is at idle then u can do little CPU cooler cleaning & can use some good quality thermal paste but its not unusual, Its quite normal!
  4. #454
    Nov 2007
    Planet Earth
    Thanks for replying.
    50 degree c is at idle and under load it goes to 61 degree c.
    I cleaned the HSF & also applied thermal paste, but then also it shows this temp .
    Blogging at:
    Technostarry
  5. #455
    In The Zone mAYHEM's Avatar
    Aug 2004
    Queensland
    Quote Originally Posted by keith_j_snyder2 View Post
    Enzotech SLF-1
    Zalman ZM-NBF47
    Nexus NHP-2200
    Evercool Serpent
    Most of the coolers use 12V while the SYS_FAN header is (GND,Speed Control,Sense, +5V).Any other cooler which supports 4 pin header.
    Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
    http://www.speedtest.net/result/445135884.png
  6. #456
    Right Off the Assembly Line roby_is_cool's Avatar
    May 2006
    Delhi, India
    hi i'm having an overheating issue with my p4 lga775 HT. it shows temp. more than 50 at idle and on bios, while on normal usage it's around 60 and on full load it goes to near 70c.
    rite now there are no fans except in the power box. my cabinet has two slots for 80mm fan in rear. please gimme some suggestions to cool it..
  7. #457
    Broken In iChaitanya's Avatar
    Oct 2005
    Pune, India
    Quote Originally Posted by roby_is_cool View Post
    Man even I had this kinda prob. wit my P4. Just fix a couple of fans in the CPU. Say, 1 inlet + 1 exhaust. You'll notice instant change in temps.
  8. #458
    Dec 2006
    Zalman ZM-NBF47, Enzotech SLF-1 & Nexus NHP-2200 doesn't require any power source so u can hook 'em with any fan u wanna. They are pure heatsinks.
  9. #459
    May 2006
    Delhi, India
    Quote Originally Posted by iChaitanya View Post
    thanx for ur advice mate, well what i'm gonna do is put one fan in the side cover and one on the rear side, let's find out if there is any improvement.
  10. #460
    The Master Chief Ronnie11's Avatar
    Nov 2006
    Mumbai
    could anyone tell me any good softwares to monitor our cpu temperature other than the Press DEL button to enter setup...i have an amdx2 processor..How can i tell what my cpu temperature is without going in BIOS??
  11. #461
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by Ronnie11 View Post
    Speedfan
    http://www.almico.com/speedfan.php
    V.Prem Kumar
  12. #462
    Nov 2006
    Mumbai
    Thanks man
  13. #463
    Dec 2006
  14. #464
    May 2008
    Hello friends.
    My rig is:
    Intel c2d e8400
    Asus P5N-D (nForce 750i SLI)
    2x2GB gskill ddr2 800 mhz (4-4-4-12-2T @ 2.09v)
    evga 8800 gt superclocked
    zebronics peace cabinet
    cm xtreme power duo 600w.
    I m running my rig at stock. My cpu temp as seen from coretemp is around 55 idle and goes upto 65 when loading. When i run orthos for about 15-20 min, temp goes upto 80 seen frm coretemp.
    In my cabby, i m having lcd temp display on cabby. wen i put sensor in to the cpu heat sink, temp display goes max upto 43 even wen running orthos.
    I dont understand wat is d prob? i m sure dat sensor is showing accurate reading bcoz wen i put sensor on NB heatsink n compare temp of mobo frm bios and display panel, it is almost same. So i dont think sensor is wrong.
    My cbby is well vantilated bcoz i m having 120 mm side inlet, 80 mm side exhaust, 120 mm back exhaust, 80mm front inlet n 80 mm top apart from cpu n psu fans.
    so wat could b the prob? is cpu temp showin are wrong or right? I think c2d should not run this much hot. is my cpu is crappy?
    Thx in advnc.
  15. #465
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by chokhu View Post
    Hello friends.
    My rig is:
    Intel c2d e8400
    Thx in advnc.
    The temperature of the heatsink will naturally be much lower than the CPU.
    First of all ensure that the heatsink is properly seated after properly applying MX-2 or AS 5.
    V.Prem Kumar
  16. #466
    Nov 2006
    Mumbai
    hey i need some help on this issue...I have an amd64 X2 4800 processor & an asus M2A-VM-HDMI motherboard...Usually whenever i start my computer...at idle it shows around 50-52C & during some workload it goes up to 60C...Is this normal by any chance??Also i have two hard disk..one is a seagate 250Gb & the other a 500gb...the 250gb at idle time is somewhere around 49-51 & some workload...goes upto 54-55C max..mostly around 52C...is this dangerous...The other 500gb hard disk has a normal temp of 46C & 49C during heavy usage...Is my computer overheating?
  17. #467
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    If the data is accurate then its definitely overheating, 54-55c for a HDD is overkill, make sure case ventilation is working, try to add a case fan and if all fails open the side of the cabbinet and use a table fan to blow air into it directly.
    Talk about extreme measures.
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  18. #468
    In The Gaming Heaven tanmoy_Siliguri's Avatar
    Sep 2008
    Just for knowledge.....what is the starting temp of a Pentium-D processor,a 160GB HDD & a 512MB DDR3 card....& what may be the avg. temp of that system???????
  19. #469
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by tanmoy_Siliguri View Post
    No idea about the proccy, HDD should be max 45c and GFx card max 90c for ATI and max 80c for nVidia.
    GFx card temp can vary depending on model, starting temperature should be= Original-15/20c
  20. #470
    RMN
    RMN is offline
    Sep 2008
    Cochin
    a small adivice from me.......to all the guys having CPU@50c at idle....re fix the heat sink!!!
    i had the same prob....on my 5th refix i got it right and now my CPU is idle @ 36c!
    DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
  21. #471
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by RMN View Post
    Make sure to clean and re-apply the thermal compound everytime you remove the heatsink.
  22. #472
    Broken In ironfreak's Avatar
    Dec 2007
    Default Im new to heating thread.... Need cooling suggestion
    How much is the ideal temp. for Pentium Dual Core ? I checked in BIOS and it showed me 45 degrees C... I think its quiet high.. Don't how did it go that high.. Just see this pic.
    I need a special CPU cooler ? Also the temp. inside cabinet is around 33 degrees C... and Im planing to have Thermaltake M9...
    will this reduce the temp. ?
    "The medium is the mess(ed) age" !
  23. #473
    Nov 2007
    Planet Earth
    ^^Speed fan
    Blogging at:
    Technostarry
  24. #474
    Dec 2007
    But whats the ideal temp for my CPU? and whats ideal temp inside any cabinet ?
  25. #475
    . JojoTheDragon's Avatar
    Aug 2008
    Guwahati
    buy and install a a glacial tech igloo
    | Steam | Battlelog | PSN | Playfire | myAnimelist |
    TDF @ Steam
    Get 2GB of free cloud space : http://db.tt/OJKPcZnY
  26. #476
    ace
    ace is offline
    Sep 2006
    hi
    i hav a problem .... my cpu has very high temp (51-53)idle &
    load temp (65-68 ) using coretemp/hwmoniter
    room temp is (29-30)
    my config
    core 2 quad Q6600 (G0 stepping) stock cooler/no overclock
    asus psk mobo
    2gb ram
    xfx 8600 gt (temp 53/65)
    powersafe 500w gold psu
    also i hav a zeb bijli cabinet (2 side fans 80mm i back fan 120mm)
    i hav applied thermal paste and reseated hsf many times....
    plz guide me , should i buy another hsf, plz giv a good option within 2K
  27. #477
    Apprentice Mike84's Avatar
    Oct 2008
    Hi All,
    I have a very old system which i use at home for downloading and stuff.
    My rig is Athlon XP 2000+ (which i keep to 2.1 Ghz overclocked when am working. else it is run at stock. After over clock the temp goes to 68C and at stock its at 60C. Its a very old system so i guess this is normal.(I do have an old CPU cooler on it.)
    My GFX card 5200FX runs at 80+C so i keep it off most of the time(physically removed). My side of the cabinet is always open for cooling. My ram is round 55C (DDR 1GB)
    But my problem is the my HDD. My PC is very slow now-a-days and i think there's something wrong with my HDD. Its showing up a whooping 186C after 30 min of work or just idle power on state.
    Please can you suggest something about it? Is there any way to reduce this temp or do i have to replace my HDD? My room feels like 10C higher than the other rooms. My HDD is acting like a room heater.
    Plz help guys...
    Athlon 2000+@2.1,MSI KM2M combo,1GB 266MHz DDR,5200FX 128MB,15" LG CRT,12X HP DVDRW
    MSI GX720 - P7350 (@2.34), 4GB DDR2 800MHz, 320GB HDD, 512MB DDR3 9600M GT,17" with 1680X1050 res. ;)
  28. #478
    Dec 2007
    Anyone knows the Intel cpu fan specs that comes bundled with Pentium dual core E2180 ??
    What are the RPM, noise level (in dBA) and bearing type of it ????
    Just reply.
    Thanks
  29. #479
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by ace View Post
    hi
    my config
    asus psk mobo
    2gb ram
    Download this software and view the temperature, only it shows the right temp values for your proccy:http://www.techpowerup.com/realtemp/
    If beyond 45c, remove heatsink, clean and re-apply thermal compound and re-attach the heatsink, its not attached properly.
    You may need the help of a technician.
  30. #480
    Oct 2008
    I have a P4 2.6 GHZ, 1GB DDR(transcend) RAM. I had overheating problem a couple of months ago so I installed another fan(currently have 2) which rectified the problem. But again this nagging problem has cropped up. What do I do now?! Can overheating be caused by RAM malfunction or corruption of BIOS?
  1. GPU, HDD and CPU overheating.
    By debarshi in forum Hardware Q&A
    Last Post: 26-07-2012, 04:35 AM
  2. Cpu overheating :\
    By TickTock in forum CPU / Motherboards
    Last Post: 10-08-2011, 03:21 AM
  3. CPU overheating!!
    By supersaiyan in forum Hardware Q&A
    Last Post: 27-02-2008, 06:06 PM
  4. overheating or something else?
    By fastc0der in forum Hardware Q&A
    Last Post: 25-09-2007, 09:17 PM
  5. Please help regarding CPU overheating ..
    By kshiraj in forum CPU / Motherboards
    Last Post: 24-10-2004, 01:18 AM
