Old 27-05-2006, 09:30 PM   #1 (permalink)
tiblu's Avatar
Question P2 Or P3
hey guys my friend owns a 433 mhz pc is it a p2 or p3, he was having 10 GB HDD but it crash down, now he wants to install a new one will it support 40 gb or should i go with 20 bg bcoz i can get 10 gb.
tiblu is offline
Old 27-05-2006, 10:09 PM   #2 (permalink)
ymhatre's Avatar
Default Re: P2 Or P3
which mobo he is having....
it solely depends on mobo u have greater HDD not proci....
I think it wuld be p3......
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 27-05-2006, 10:50 PM   #3 (permalink)
phatratt's Avatar
AFAIK P2's fastest processor was 350mhz,check the socket number,if it is socket 7 then its a p2,if it is written socket 378 then is a p3.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 27-05-2006, 11:54 PM   #4 (permalink)
dattebayo
anispace's Avatar
i think fastest P2 was 450MHz. also P2`s had slot loading interface.
why dont u open the cabinet and see it urself or u can use a system info tool.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 28-05-2006, 09:23 AM   #5 (permalink)
tiblu's Avatar
My freind has heat sink fan just like our p4 or amd. It doesn't hav slot loading cpu
tiblu is offline
Old 28-05-2006, 11:07 AM   #6 (permalink)
samrulez's Avatar
it must be a p3.coz I had a p2 and that did not have a heat sink only one 20 mm fan.but still is it socket 7 ??
Sam :D Rulez :lol:
samrulez is offline
Old 28-05-2006, 03:32 PM   #7 (permalink)
phatratt's Avatar
^^^i don't think there was any P3 processor that sat on a socket 7.
phatratt is offline
Old 31-05-2006, 12:32 AM   #8 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
plz frame the question in a proper way... i m unable to understand what u mean to say ....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 02-06-2006, 10:00 AM   #9 (permalink)
Post Re: P2 Or P3
PII was never Socket 7...
Socket 7 was used till Pentium MMX 266 Mhz
Then came Pentium II with Slot 1
the standing type......
If u say u have Heatsink and then chances r that u might have AMD as
pentium 1 never crossed 300 mark and was socket 7 with heatsink and FAN
pentium II was a Slot Peocessor FAN and Heatsink on SIDE instead of being on Top.... you can see Pentium II printed on IT
Initally Pentium III was also launched as Slot 1 Processor but till 533 Mhz
then arrived new Pentiums III Slot / Tray processors just like Socket 7 but used Socket 378 with FAN and Heatsing on Top
In ur case none of the above Fits so it might be AMD K6-2 433 Mhz
use CPU-Z to check what is make and model of ur CPU
http://www.softpedia.com/progDownloa...load-6980.html
and do inform what was ur findings.........
ANXIOUS to Know the Results....
happy hunting
Sharing Knowledge Expands Horizon... And Problems r solved
bikram_singhy is offline
