Guys,
I thank all of u out htere who'd helped me. But I do need ur help once again.
Most of you have suggested that the 400W Powersafe psu wont match for the 3500+ and 7900GT combo. Fine.
1.But does that really imply I would be unable to run the rig fine on that power?
2.So far I havn't connected my system coz I'm away from my home(Kerala) where my monitor is.( I'm in Amritsar.)
While assembling the gfx card, I found that it came with a power connecter, that requires it to be connected to two 12v molex connectors( one that goes into cd drives).
But my psu has been spared with only one 12v molex connector. However there is a 4pin small white connector that is parallelely derived from another 12v molex connector. I havn't connected a floppy drive either. Can I use this small connector to be used with the other 12v molex connector of the gfx card?
Or can I use one 12v molex connector to distribute it to the 2 12v molex connectors of the gfx card by connecting it parallel.
Please do reply,
Ganesh
