Old 27-05-2006, 01:39 PM   #1 (permalink)
ashfame's Avatar
Question SLI 7600gt / 6600gt
how much 7600gt is better than 6600gt?
1. if used as alone.
2. if in sli.
Pl explain how does sli work!
One more :
Can two 7600gt[s] be made in sli or one 7600gt & 6600gt can also be made to work in sli.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 27-05-2006, 02:13 PM   #2 (permalink)
Default Re: SLI 7600gt / 6600gt
7600GT is slightly better than 2 6600GT's in SLI.
Both cards have to exactly the same to use SLI.
drvarunmehta is offline
Old 27-05-2006, 02:57 PM   #3 (permalink)
deathvirus_me's Avatar
Well .. a single 7600GT should be the same as a 6600GT SLi .. u can further SLi the 7600GT .. which will even perform better than a 7900GTX ....
deathvirus_me is offline
Old 27-05-2006, 06:50 PM   #4 (permalink)
dude forget 7600 buy x1800 GTO crossfire u can put 2 cards and kick ass
And advantage of x1800 GTO is 256bit,HDR & AA can be enabled together and costs just $30 more and if ur lucky u can mod it to X1800 XL.
Srch net for X1800 GTO reviews
snake is offline
Old 27-05-2006, 07:06 PM   #5 (permalink)
ashfame's Avatar
u mean setting up 6600gt in SLI is euivalent to a single 7600gt?
if yes then why not buy a single 7600gt instead of setting up 6600gt in SLI mode.
i mean it would cost less?
is there any more advantage if the cards are in SLI?
can someone clear the diff. in powers of 6600gt, 7600gt, 7900gt
ashfame is offline
Old 28-05-2006, 01:45 PM   #6 (permalink)
ashfame's Avatar
well final deal is that setting up 7600gt in SLI is the best option & won't cost u above 15k.
what are the other requirements for setting a SLI based PC.
ashfame is offline
Old 28-05-2006, 01:53 PM   #7 (permalink)
Hanging, since 2004..
tarey_g's Avatar
7600GT x 2 = 15,000 /- i dont think 7600gt's are so cheap
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 28-05-2006, 03:47 PM   #8 (permalink)
ashfame's Avatar
one 7600gt is available for Rs.7650, so a sli will cost Rs. 15300 ~ 15k
ashfame is offline
Old 28-05-2006, 05:57 PM   #9 (permalink)
tarey_g's Avatar
holy cow !!!!!!!!!!!!!!!!!!!!!!!!!!!! , for 7650 Rs where ?
Windows 8 ? :lol:
Old 28-05-2006, 06:28 PM   #10 (permalink)
ymhatre's Avatar
Maddd..........
Where on earth currently u r gettin 7600 GT for 7K - 8K....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 28-05-2006, 07:17 PM   #11 (permalink)
From what I would most probably say and go with:
7600GT>=6600GT SLi
7900GT>=7600GT Sli
7900GTX+-=7900GT SLi, however I may prefer a single 7900GTX rather than 7900GT, not fully made up though
1800GTO maybe a better option than 7600GT however a 1900XT will beat the ass of the unmodded crossfire of 1800GTO
PM me for details
akshayt is offline
Old 28-05-2006, 07:18 PM   #12 (permalink)
Also, 7650, nowhere in india
for that cost you may get a 6600gt , but that too not every where
7600GT at the moment will set you back >12k
akshayt is offline
Old 28-05-2006, 10:23 PM   #13 (permalink)
ashfame's Avatar
there is DCE paper on 30th may after that i will confirm the 7650 holy cow.
wait till then!!
kk
ashfame is offline
Old 28-05-2006, 10:29 PM   #14 (permalink)
of course 7600gt sli,provided u can afford it.
supersaiyan is offline
Old 28-05-2006, 10:52 PM   #15 (permalink)
no sli, 7900GT or Radeon 1900XT all the way
There are people who may even argue that 1900XT is a better choice than 7900GT SLi
akshayt is offline
Old 29-05-2006, 03:53 AM   #16 (permalink)
aryayush's Avatar
It's impossible to get a brand new legally purchased 7600 GT for Rs. 7,650. Even my card costs Rs. 9,000.
aryayush is offline
