Originally Posted by cyrux
There is supposed to be a LED on the motherboard . Just check if its lighting up.
One way to see whether it is working is to disconnect all connectors, disconnect the mains supply, and then make a connection between green and black wires in the 24/20 pin connector to the Mobo (using a small piece of wire) and then connect and switch on the mains. If it is alright, the SMPS fan/s should start revolving. Then if needed, you can check the voltages using a multimeter.
May be there are simpler methods but this is all I know and I hope others in the forum will also suggest.
