Re: Will this power supply be sufficient?
A PSU of 400, 430 or 450 should be sufficient if it is a well known brand like Antec. The reason is that in such cases, they specify the current ratings for different voltages which should be reliable. But in case of unknown or local brands which are cheap, the specifications are very often exaggerated.
By no means do I imply that you should go for costly brands like the ones mentioned. If you search, you will get good quality PSUs at half the cost of an Antec.
I can only suggest a simple rule of thumb. The heavier, the better.
V.Prem Kumar
