Originally Posted by samrulez
There is 1 more thing I don't get the core speed is only 995 MhZ.In my 2800+ it shows 1800MhZ.Can u tell me why?
You might have enabled Cool & Quiet. If so, the idling speed will be around 1000 MHz and will go up whenever you open CPU hungry applications.
For checking the voltage, you can do it in the Bios, with CPU-Z, Asus Probe or similar softwares. But I feel the results from these softwares are generally reliable but not always accurate.
