Old 24-05-2006, 08:07 PM   #1 (permalink)
ratzee199's Avatar
Default plz help me selecting an AGP CARD???
hi
my pc config is like this:
P4 2.8 Ghz HT, Intel 865GBF motherboard, with agp 8x slot. It has 768MB DDR. currently i hv MSI GEFORCE 5600 FX 256 MB ddr agp card.
but now i want to upgrade it to Ge Force 620/6600. Please help me to choose one. My budget is around Rs 8000-Rs 10000. Plz help.......as i am not able to enjoy the game FEAR, SPLINTER CELL:CHAOS THEORY etc..
and as i am living in MUMBAI, so can you plz lemme know(if possible) where can i buy the cards or get the cards ??
ratzee199 is offline
Old 24-05-2006, 08:14 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: plz help me selecting an AGP CARD???
Go for 6600GT. The 6200 is a very low end card..
kalpik is online now
Old 24-05-2006, 09:13 PM   #3 (permalink)
ymhatre's Avatar
6600 GT will fit ur budget...
Also Laminton rd is paradise for PC buyers in MUMBAI...
If u stay far in suburban... Then theres a place called sunil Shopping center in Andheri WEst....
It will cost u abt 50 - 100 RS more than lamington.....
BUt in such cases its better to get from nearby
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 24-05-2006, 09:48 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
6600GT XFX/gainward that fits ur budget...128mb ddr ram
laminton road..even if u stay anywhere in mumbai....
As if people can come form outside mumbai to lami then u can and u should....
the options and variety u get there is not comparable.....
u will not come empty handed adn will get wht u want (if u insist and know to find it )
wizrulz is offline
Old 24-05-2006, 09:59 PM   #5 (permalink)
mayanksharma's Avatar
10000 bucks!! Ok look out for following cards dude:
Gainward 6600GT golden sample,XFX 6800GS DDR3(AGP),XFX 6600GT with 256MB of GDDR3 and Ati X600.
Go with Gainward make if possible,proper moddings can be done to this card,also.
mayanksharma is offline
Old 24-05-2006, 10:16 PM   #6 (permalink)
samrulez's Avatar
6200 is a low end card....If u, can spend about 10000 then u can get a
6600GT 256 MB.With a 6600 GT u can njoy all games at 1024X768,with good FPS.
Sam :D Rulez :lol:
samrulez is offline
