Old 24-05-2006, 06:43 PM   #1 (permalink)
Default pc restarts itself
My PC restarts itself sometimes after that restart a dialog box depicting following message appears: " Windows has recovered from serious error..." my PC's config. : AMD duron 1.2 ghz on MSI KT3-Ultra mobo with 128 mb of ram and g2mx agp card with WIN XP Home (build:2600) without any service packs. This restart happens sometimes / occasionally.
niraj_dixit is offline
Old 24-05-2006, 07:07 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: pc restarts itself
Most probably a RAM/PSU problem..
kalpik is online now
Old 24-05-2006, 07:13 PM   #3 (permalink)
deathvirus_me's Avatar
A faulty ram i think ... try another diff. module ...
deathvirus_me is offline
Old 24-05-2006, 09:09 PM   #4 (permalink)
ymhatre's Avatar
Try swapping ur rams to different slots....
Its usualy related to ram or other may be overheating, PSu
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 24-05-2006, 10:52 PM   #5 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
yup its a overheating problem.... if it would have been a faulty RAM then the computer would have refused to start....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 24-05-2006, 10:56 PM   #6 (permalink)
samrulez's Avatar
It may be a ram problem.Check if it is properly sitting on the slot.
Sam :D Rulez :lol:
samrulez is offline
