Old 23-05-2006, 11:03 AM   #1 (permalink)
Unhappy geforce 6200 can't work on 9100igp
please help me guys
i recently bought a xfx geforce 6200 256 mb agp card
it does not work on my gigabyte 9100 pro igp motherboard
the games run fine but the icons looks srached the pictures are also scrached
i m useing windows xp sp2
pentium 4 2.4 ghz
512 400mhz ram
PLEASE HELP ME
PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE!!!!!!!!!
kamal_4176 is offline
Old 23-05-2006, 11:46 AM   #2 (permalink)
Default Re: geforce 6200 can't work on 9100igp
update your graphic card driver...
nvidia.com
robin345 is offline
Old 23-05-2006, 02:11 PM   #3 (permalink)
samrulez's Avatar
Post Re: geforce 6200 can't work on 9100igp
6200 is a good graphics card in its budget..To slove ur problem update the graphics card's drivers and if possible the bios also (Only from the official website)That should solve the problem...
But avoid updating the bios,,1st update the drivers.Then if that does not work then go with the bios update.!!
Sam :D Rulez :lol:
samrulez is offline
Old 23-05-2006, 10:35 PM   #4 (permalink)
deathvirus_me's Avatar
what is the desktop bit depth ?? coz upon installing the driver newly .. its set to 16 bit . which is horrific .. set it to 32 bit ...
deathvirus_me is offline
Old 24-05-2006, 10:51 AM   #5 (permalink)
Well i think this graphic card is not compatible with ur mother board why dont u swap some other graphic card and check it is working or not i dont think upgrading ur driver can solve ur problem cause driver comes with new card is already new and updated anyway plz visit [edit: stop promoting your forum like this - your sig is enough.]
http://techmatch.blogspot.com
Tutorial and Guide to Softwares, blogging and internet.
aryan333 is offline
Old 03-06-2006, 03:36 PM   #6 (permalink)
thanks guy's
for all ur help but i concluded that only 78.1 ver of forcware works
as my card is agp the newer drivers detect it on pci so with the newer drivers i can't select the 16 or 32bit colour depth
