Old 23-05-2006, 10:17 AM   #1 (permalink)
Default New PC Please recommend
Hi !
I am considering to buy a new PC in couple of days and have come to following config. Please suggest if anything missing / better can be added. My budget is abt 50,000 rs. ( i asked some vendors and it comes close to that. is it okay ? )
CPU : intel pentium D 805 Rs 6000 /-
Mobo : intel 945G based ( GNTL ) Rs 5800 /-
( hardcore intel fan )
RAM : Transcent 2 GB DDR2 8200 /-
HDD : 300 GB Seagate 5400 /-
Graphic Card : please suggest ( ati radeon x1600 pro 512 MB Rs 12,250 /- )
Sony DVD ROM Rs 1150 /-
Lite-On DVD Writer Rs 2450 /-
Any suitable Cabinet and P.S. Rs 2400 /-
Samsung 798 MB 17 inch Flat CRT monitor Rs 6450 /-
Logitech Keyboard + Optical Mouse Rs 900 /-
Is it okay ? Also Please sugget abt the Graphic Card
Thanks in advance !
Bye !
chitta is offline
Old 23-05-2006, 11:39 AM   #2 (permalink)
bang bang!
Chirag's Avatar
Default Re: New PC Please recommend
Get Xfx Geforce 6600gt PCI-e 256mb ram. It costs Rs. 11k
Seeing ur rig I think u r a gamer. Than I think u shld go for AMD. Anyways u r Intel Fan its ur choice.
Chirag is online now
Old 23-05-2006, 12:30 PM   #3 (permalink)
digiFriend's Avatar
Smile Re: New PC Please recommend
buy cpu cooling system for your processor.
(Pentium D 805 processor is very good for overclocking.
intel pentium D 805 processor speed is (133*20)= 2.66Ghz
most notable feature in this processor is 20x multiplier.
as multiplier is locked by intel, the way to overclock it is by increasing the clock speed for the front side bus.
if FSB speed is raised to 200 MHZ it result (200*20)=4.0 Ghz
labs test results of tom's hardware shows stable operation was possible at (205*20)= 4.1 GHz.
if overclock this low cost processor can outrun many very high cost processor.)
you never know what you can do until you try
digiFriend is offline
Old 23-05-2006, 02:05 PM   #4 (permalink)
samrulez's Avatar
Post Re: New PC Please recommend
Are u sure PD is only 6000 coz even AMD Athlon64 3200+ single core costs more than that !! But with 6000 u cannot get a AMD Dual core processor....coz 3800+ X2 costs almost its double.
And 8xx PD heat up too much,,so get a good cabinet...
And if u can,then try to go for PD 9xx series,,its better
Rest is fine,,,...
For the graphics card go for 6600 GT PCIe 256 MB.With this graphics card u will be able to play all games...easily!!>>
Sam :D Rulez :lol:
samrulez is offline
Old 23-05-2006, 03:21 PM   #5 (permalink)
I have a Radeon X1600Pro and while I find it's performance really satisfactory I really don't see the need for 512 MB.
drvarunmehta is offline
Old 23-05-2006, 03:44 PM   #6 (permalink)
E.T.'s Avatar
945 mobo seems to be quite cheap. Where did you get it from.? Get the ATI All-In-Wonder card and may be a Antec cabinet and PSU.
%íf6¦Kª£yþXØ {ÛT?ÇS?Tº]æZjÙEM<?>B?*l½HÖ¥ÿW¹ÿ¥ªµ?ÿ?R¥q9µW%*h%õ´a e4ËäJw?bØ&8³Bz'cyW
E.T. is offline
Old 23-05-2006, 04:33 PM   #7 (permalink)
People in this forum don't even know what they are talking of.
1600Pro A BIG NO!
6600GT for that budget NO NO NO!
256mb with Geforce 6600gt is not much of a gain, such a weak card can't even make use of that much more vram
for around 11k go for Geforce 6800GS 256mb which performs equal to a 6800GT if not better,
For about 12.5-13k go with 7600GT
For Rs.18750 go for Asus Geforce 7900GT 256MB from Prime, recommended option
also, if you really wanna game,go for amd and not intel
akshayt is offline
Old 23-05-2006, 04:35 PM   #8 (permalink)
A 7600GT which is much much better than 1600XT, 1600Pro and 6800 and 6600gt and even better than 6800gs can't paly games like FEAR at 1024 with soft shadows on.
6600gt and 1600Pro/XT maybe fine for med settings at 1024*768 or 800*600 for newer games
akshayt is offline
Old 23-05-2006, 05:45 PM   #9 (permalink)
the deconstructionist's Avatar
U are a lucky chap , go for Nvidia but make sure it is 512 MB and don't forget a good cooling system and Ups.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 23-05-2006, 06:06 PM   #10 (permalink)
Does the X1600Pro even cost that much? At that price you should get a 7600GT.
A Pentium D 805 dual core proccy is a very good choice indeed. You don't have to buy AMD to have a good gaming experience.
If you drop the DVD ROM drive and take 1 GB instead of 2 GB RAM, you could get a good 8ms 17" LCD. It should cost about 12-13k.
Old 24-05-2006, 11:34 AM   #11 (permalink)
see techtree buying guide at www.techtree.com
rohitm_001 is offline
Old 24-05-2006, 12:32 PM   #12 (permalink)
have a look at tomshardware.com and xbitlabs.com/articles, they give higher fps though so you will only get a fraction of that
akshayt is offline
