Old 22-05-2006, 09:34 PM   #1 (permalink)
royal's Avatar
Question need a mid range TV tuner card
hey the world cup fever is catching on ...
I badly need a tv tuner card ... mom wont let go of the tv (watches all kind of serials the whole evening )
I need a tuner that can capture TV shows directly into DIVX format along with the Time Shift facility as well as Scheduling ...
probably it will be an external (USB 2 interface ) one ... I dont have any problem with that ... moreover its better if this costs max. Rs. 4000
So pls suggest me models and prices
Like I said , I need this bad...so kindly help me
royal is offline
Old 22-05-2006, 11:05 PM   #2 (permalink)
Default Re: need a mid range TV tuner card
Hi There!
Well, regarding tv tuner cards, the best brand that I came across was Pinnacle.I have a Pinnacle PCTV Stereo TV tuner card and its excellent.Priced at 2500 Rs, it performs at an Unmatched quality and at a very good resolution.You can record tv shows in Divx format using Nero Vision(Nero 7 and above).Visit www.pinnaclesys.com for more info.
Enjoy
astropollo is offline
Old 23-05-2006, 12:33 AM   #3 (permalink)
kichu_overclocked's Avatar
well dude....go for pinnacle as it is the best.......n by any chance if u come across a Typhoon tv tuner card, plz break it into pieces n throw it out of the window!!!!
cheers
Mukul Soman
kichu_overclocked@yahoo.co.in
AMD Athlon3200+ running @ 2.6 GHz(one hell of a performer)
Asus A8N Sli mb
1 GB Hynix ram
160 GB Seagate HD
sony dvd writer
lite on dvd rom
Twin XFX 6800 xt cards working in SLI(my babies)
Custom coolant /water cooling by corsair cool
PowerSafe 600W smps
addons: seagate 6 gb pocket drive
Lexar 1 gb pen drive
kichu_overclocked is offline
Old 23-05-2006, 07:55 PM   #4 (permalink)
royal's Avatar
hey astropollo
does your tuner have Phillips chip If not then the quality would not be good
BTW, how much space does a 1.5 hour movie in DivX format occupy on your hard drive ?
I presume the card has the time shift/scheduling and the usual features ?
Is it an external one (usb 2) ? any FM radio options ? what is the bundled software ? how's the remote ?
I heard Pinnacle Media Center tuners are better than PCTV series (and costlier as well )... do I need to have Windows Media Center installed to use it
royal is offline
