Re: Is this Dangerous
The noise is likely to be from fans of CPU, chipset or cabinet. Try cleaning them and ensure that no wire is touching them. Also you can try replacing the cabinet fans with high quality/low noise ones from brands like Antec, Coolermaster etc.
Regarding flickering, try setting the refresh rate to 75 or higher. If it is not possible, reduce colour depth and try again.
Hope this will solve the problems. Anyways, try and pl report back.
V.Prem Kumar
