Old 19-05-2006, 03:04 PM   #1 (permalink)
friend_sunit's Avatar
Wink converting hard-disk to ram
hello i have a RAM of 64 MB and on the other hand a huge hard-disk of more than 50 GB free-space. Isn't there any way that some of the hard disk space may be used as RAM without buying a new ram. many games don't run on my pc.
friend_sunit is offline
Old 19-05-2006, 03:07 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: converting hard-disk to ram
u are already using a part of your hard disk as RAM.
It's called the page file.
dIgItaL_BrAt is offline
Old 19-05-2006, 03:12 PM   #3 (permalink)
you can increase the pageing file or Virtual memory
Right click on my computer -->Properties -->Click on Advance--->Virtual memory (change )..Pu the required the values you want ..but i will suggest you to increase you PCs ram ...
robin345 is offline
Old 19-05-2006, 03:36 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Hey buddy, you alredy have this one in Software troubleshooting here. Double posting not allowed.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 19-05-2006, 07:48 PM   #5 (permalink)
deathvirus_me's Avatar
Well ... theoritacally yes .. but practically no ... ur ram is way faster than the hdd ... and if u do use hdd space for temp. file storage then u'll definitely end up having a degraded performance. ...
Simply put ... ur pf is the virtual ram shared from the hdd ...
deathvirus_me is offline
