Old 18-05-2006, 02:01 PM   #1 (permalink)
Default Help needed in making a pc in the range of 35-36k
hello der everyone plz can u help me in building a pc for the range of 35k-36k for my cousin bro he needs its mainly for some lite games nd browsing nd music i m frm delhi so it wulkd be better if i culd get the prices of delhi
nd is there ny site tht has all these prices of the components
plz
thnx in advance
shikhar_kapoor143 is offline
Old 18-05-2006, 02:13 PM   #2 (permalink)
Aniruddh's Avatar
Red face Re: Help needed in making a pc in the range of 35-36k
for price u can check this- www.deltapage.com
u can go for the following config:-
1-AMD64 3000+,3200+ (939 socket)-5.5k/7.5k
2-Asus A8N-VM CSM MOBO-4.5k
3-256*2 or 512*2 400MHz (Kingston,Transcend) Ram-2.2k/4.2k
4-DVD-RW (SONY)-2.8k
5-Samsung 17" Flat CRT Monitor-Sm 793MB,798MB-6.5k
6-Logitech MM KB & Optical mouse-.8k
7-Altec Lancsing ATP3 (2.1),Altec Lancsing 251(5.1),Creative Inspire(5.1)-2.8k/3.8k/3.9k
8-Seagate 160GB SATA-3.8k
9-Powersafe 400watt SMPS-1.3k
10-Numeric 600VA UPS-1.8k
11-Cabinet of ur choice-1k
this config shud come under 35k.
For casual gamer this is a pretty decent rig.
Aniruddh is offline
Old 18-05-2006, 02:24 PM   #3 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default Re: Help needed in making a pc in the range of 35-36k
See post no.1 of this thread:
All configuration (new and upgrades) related queries here
Your exact query is solved there.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 18-05-2006, 06:48 PM   #4 (permalink)
aryayush's Avatar
I would recommend the same config but if you can extend your budget just a little bit (maybe Rs. 2,000) and you sacrifice on something in the above config, you can throw in an XFX GeForce 6600 GT 128 MB graphics card as well (I don't know the exact price, maybe someone living in New Delhi can guide you).
aryayush is offline
Old 18-05-2006, 09:19 PM   #5 (permalink)
1-AMD Athlon 64Bit 3000+ Socket 939 Venice Core E - Rs 5300
2-ASUS A8N-E - Rs 5300
3-XFX/Leadtek Nvidia Geforce 6600 - Rs 5500
3-Transcend RAM 512*2=1GB 400MHz - Rs 4400
4-Lite-ON/LG 4163B DVD Writer - Rs 2400
5-Samsung/ViewSonic 17" Monitor - Rs 5000
6-Multimedia Keyboard && Optical Key board - Rs 600
7-Altec Lancsing 251 5.1 Speakers - Rs 3800
8-Seagate 80GB SATA - Rs 2400
9-Zebronics antibiotic Cabinet with 400W SPMS - Rs 1500
Total - Rs 36000
chota_rod_waala is offline
Old 18-05-2006, 10:42 PM   #6 (permalink)
aryayush's Avatar
Eighty GB is too meagre, man! Get a hard drive above 150 GB.
aryayush is offline
Old 19-05-2006, 10:57 AM   #7 (permalink)
samrulez's Avatar
yep all are ok but definitly go for 1 gb ram since Vista will require it.The graphics card is more than enough.And go for a 160 GB SATA HDD.
Sam :D Rulez :lol:
samrulez is offline
