Location: If I had a webcam u could have seen me, before your eyes.
com port
I m using a external modem which is connected to COM port 1..... through a 9 pin connector....but I want to connect another device onto this com port and also run my modem simulteanously.... can it be done.... ok instead of connecting both on the same port,,,, can we connect the modem to any other,,, plz help ,,, remember I have a 9 pin connector common to both these devices....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
If you don't have another port connector coming out from your board, you can buy one and attach it on motherboard. surely your motherboard will have option for another port. else try for 9 pin to usb converter.
