Old 15-05-2006, 09:01 PM   #1 (permalink)
Default Samsung 793DF problem
I recently bought Samsung Syncmaster 793DF monitor for myself. But right from the first day horizontal brown lines are coming on the screen. These lines comes and go in a second. This is happening once in a hour. What could be the problem?? I called a serviceman from Samsung, he done something but still I'm facing the problem. Anyboady is facing the same problem..??
parimal is offline
Old 15-05-2006, 09:33 PM   #2 (permalink)
tiblu's Avatar
Default Re: Samsung 793DF problem
try deguassing it. Its in the menu of monitor
tiblu is offline
Old 16-05-2006, 07:47 PM   #3 (permalink)
I tried that but not helping....anything else I can do?
parimal is offline
Old 20-05-2006, 09:34 AM   #4 (permalink)
Knock! Knock!! Anybody in there....??
parimal is offline
Old 01-10-2008, 01:56 PM   #5 (permalink)
i am facing same problem.. At the very begining the promlem was as like as you. But now it becomes so painful that i cant explain it. the letters on the screen cant be seen right now. sometimes it is spreaded all over the monitor. This is happening continuously. I showed my monitor to electrician but they are not able to fix the problem. What should i do? Does anyone have the solution for it???????
arafatctg is offline
Old 01-10-2008, 03:30 PM   #6 (permalink)
The Black Waltz
You may have to reinstall your display drivers....
#krow @ irc.freenode.net
Cool Joe is offline
Old 19-11-2008, 08:42 PM   #7 (permalink)
Had to bump on a very old post but can't help writing. Actually i too have the same monitor and i suffered the same problem.
Reason : - THESE ARE FAKE OR DISCARDED MONITORS, confirmed by the Samsung India Guy.
Right now i dont find anything special to mention in my signature
zatang is offline
