Old 15-05-2006, 05:14 PM   #1 (permalink)
Default Sony DW-Q120A Problem...
Hi,
I bought this new DVD writer..But it doesnt read the files..Its shows an
I/O Error...(MY OS is XP SP2)...The i connected the drive to my friesnd's PC
(XP without SP)..Then it worked...
Please give me a solution
anilthomas26 is offline
Old 15-05-2006, 11:45 PM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: Sony DW-Q120A Problem...
try on another IDE port, another cable....
as u said it works on friends' pc...
do other drives work fine on yours
Kniwor is offline
Old 16-05-2006, 02:17 AM   #3 (permalink)
yes the CD Drive works fine........................
Old 16-05-2006, 09:15 AM   #4 (permalink)
Learner
Kniwor's Avatar
then have u trien it on that port/cable on which the CD drive is working...
also give details of your mobo
Kniwor is offline
Old 16-05-2006, 09:02 PM   #5 (permalink)
thnxxx..the prob was with the cable......i changed it now it is working
ThnX a lot
Old 17-05-2006, 01:08 PM   #6 (permalink)
Learner
Kniwor's Avatar
when u solve many problems like this it will not take u time to figure out such things.... lol...
Kniwor is offline
