Old 14-05-2006, 02:21 AM   #1 (permalink)
samrulez's Avatar
Default Which Ram Transcend/Hynix/Corsair/Kingston/Zion
I have an AMD Athlon 2800+ on an MSI K8N Neo-V,with a 80 Gig SATA HDD.I have 256 MB of ram at 333 Mhz.I want to buy another 256 MB chip running at 333 Mhz.Should I go for Transcend/Hynix/Corsair/Kingston/Zion pls tell me the prices of all.........
samrulez is offline
Old 14-05-2006, 02:24 AM   #2 (permalink)
ECE0105's Avatar
Default Re: Which Ram Transcend/Hynix/Corsair/Kingston/Zion
Try Transcend or Kingston....
These are the best... I gues Corsair is good too. Check with the other members.
ECE0105 is offline
Old 14-05-2006, 05:00 AM   #3 (permalink)
Learner
Kniwor's Avatar
Get the ram that u already have
If it's a transcend, get transcend...
although it will be hard to find an identical stick if it's Hynix, but try to find an stick same as ur current one.....
if u purchased ram with any of ur friends, i mean u 2 purchased ram together, and he has the other identical 256Mb in his comp... use that and get him another ram....
otherwise, I'll say corsair value select is still better than all that's available in india
Kniwor is offline
Old 14-05-2006, 01:17 PM   #4 (permalink)
royal's Avatar
Smile Re: Which Ram Transcend/Hynix/Corsair/Kingston/Zion
yeah ... go for CORSAIR or KINGSTON best ones in India
royal is offline
Old 14-05-2006, 02:19 PM   #5 (permalink)
abracadabra's Avatar
zinon and hynix are much the same. stay away from these. my presonal choice wuld be coorasir, they are one of the leading ones or go for OCZ*. Choose ones with heat spreaders they culd be expensive but a real gud choice
*subject to availabilty in INDIA
abracadabra is offline
Old 19-09-2007, 11:51 AM   #6 (permalink)
I seriously disagree. i've been using a ZION ram for quite sumtime now and am really satisfied with its performance. After having warranty issues with Corsair, I tried ZION and am glad i did tat.
mumbaiite123 is offline
Old 19-09-2007, 12:02 PM   #7 (permalink)
bajaj151's Avatar
If possible...buy same ram...
or go for transcend.....
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 19-09-2007, 03:24 PM   #8 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
corsair>>kingston>transcend>zion>?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 19-09-2007, 04:24 PM   #9 (permalink)
I would recommend to go for whichever brand u get. Reason: DDR1 is not easily available (especially DDR333 and lower). Corsair had stopped making these RAMs eons back and now finding even Kingston DDR400 256 MB is rare. So you will have to settle to other brands (I have DDR1 400 MHz RAMS 4x512MB size - 2 Corsair and 2 Transcend - I couldn't find Kingston DDR400 512 MB just few days back anywhere in Delhi).
I would recommend you to find DDR400 modules and use them instead of DDR333. Try anywhere, including online shops like ebay.in.
Good luck.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is online now
Old 19-09-2007, 04:34 PM   #10 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
its better to use a single 512mb ram stick.....u can buy zion ddr400
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 20-09-2007, 06:38 PM   #11 (permalink)
Alpha Geek Banned
bikdel's Avatar
guys...... lokk at the date.......... THE POST IS OF 14TH JUNE 2006!!!!
hey.. who rediscovered this ol post......heheh???
bikdel is offline
