Old 13-05-2006, 11:23 PM   #1 (permalink)
The Sexy Beast
Question Hanging problem with optical drive
almost every time my pc hangs after putting a cd in my drive. so i often have to restart my pc.it is most common with autoplaying cd's.
p4,intel 915,sony cd drive and asus cd-rw.
ratedrsuperstar is offline
Old 13-05-2006, 11:32 PM   #2 (permalink)
samrulez's Avatar
Smile Re: Hanging problem with optical drive
Are the CDs u use in good condition??The problem may be that the CD s are scrached ////\//\/\/\\\\\\\\\\\\////
Do any thin' 4r u r passion!
samrulez is offline
Old 14-05-2006, 05:16 AM   #3 (permalink)
Learner
Kniwor's Avatar
Default Re: Hanging problem with optical drive
if it's with all cd's ... something is wrong with ur drive....
if it's some specific CD, conclude the CD is corrupt
Kniwor is offline
Old 14-05-2006, 08:53 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Check if DMA is enabled (device manager -> IDE/ATAPI controllers).
kalpik is online now
