Old 13-05-2006, 02:32 PM   #1 (permalink)
Default reset BIOS password ?????
hi,
is there any means by which i can reset the BIOS password by running some application?. always opening the cabinet and then removing the battery is not the best option,i think so (but its the most common too). i like to do the same via application.
any idea, gurus
reg
taken is offline
Old 13-05-2006, 02:43 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: reset BIOS password ?????
to the extend of my know how it can be done through jumper or battery
gary4gar is offline
Old 13-05-2006, 03:12 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Following link will help U:
HOW TO BYPASS BIOS PASSWORDS.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-05-2006, 11:19 AM   #4 (permalink)
thanks Vishal Gupta... i will go through it and hope that i come out sucsessful.
taken is offline
