Old 13-05-2006, 02:52 AM   #1 (permalink)
samrulez's Avatar
Default AMD Athlon 64 3000+/1.8--2.7 ???
Is the stock speed of 3000+ (939) 1.8 Ghz?But I have heard that it can be overclocked to 2.7 ghz.I have a 2800+(754) with a stock speed of 1.8 Ghz,How much can it be overclocked?I have a MSI K8n neo V with 512 MB of Ram.Also, while overclocking should the temperature be the only concern?Can I keep overclocking it till the temp is under control?
samrulez is offline
Old 13-05-2006, 04:31 AM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: AMD Athlon 64 3000+/1.8--2.7 ???
lol....
no, the stability is our first concern, then the tempetature, voltage control is important.
if u just go on increasing the speed u will not reach 2.7Ghz
u might want to read these posts
http://www.thinkdigit.com/forum/show...93&postcount=2
http://www.thinkdigit.com/forum/show...8&postcount=60
Kniwor is offline
Old 13-05-2006, 03:11 PM   #3 (permalink)
samrulez's Avatar
Thanks.Can u tell me how much can my CPU be Overclocked.(2800+)(754)the approximate speed after overclocking.Can it reach 2.4 or above ????
samrulez is offline
Old 13-05-2006, 04:18 PM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Overclocking depends on different components and its quality. But remember o'cing void ur warranty. There are some good guide in the tutorial section, check those out A newbie's guide to Overclocking a Athlon XP CPU. Also ask Kniwor and Darklord, they could help u a lot.
john_the_ultimate is offline
Old 13-05-2006, 06:21 PM   #5 (permalink)
Learner
Kniwor's Avatar
U can not know how much a cpu can be overclocked until u overclock it.....
surely it can reach 2.4, and pass beyond it...
just check ur BIOS, i never had the chance to see BIOS for that board... see what options are there.... if u dont understand things.. all for help again
Kniwor is offline
Old 13-05-2006, 06:54 PM   #6 (permalink)
samrulez's Avatar
How does oc'ing void the warranty???Even if I oc it once and then run it at normal willl that also void the warranty.Does it have a lock or something??I had overclocked it once for 1 or 2 dayz,has the warranty expired???Pls send me a link to the stability software...
samrulez is offline
Old 13-05-2006, 09:49 PM   #7 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
i have a A64 3000+ on A8N SLI Prem..
i have reached stable core speeds at
cpu_289x9(2.6ghx) @ vid_1.475 htt_4x
stability test by prime95 and OCCT
you have to do lots of burnins to achieve higher oc rates
Rollercoaster is offline
Old 13-05-2006, 11:39 PM   #8 (permalink)
deathvirus_me's Avatar
Well ... if u intend to lower ur ram frequency and htt and oc the processor ... and if u finally reach the limit for the processor and don't cross the default ram frequency .. u'll lose out a lot of performance in case of Athlon processors ... lol ... so unless u have good ram don't oc your processor .. ...
deathvirus_me is offline
Old 14-05-2006, 05:14 AM   #9 (permalink)
Learner
Kniwor's Avatar
@samrulez
overclocking voids the warranty, this is a warranty condition of the manufacturer, so if u have a burnt cpu and tell AMD that it got burnt while u were overclocking it.. then u wont get a replacement... but in general, they will not try to find out if u have overclocked it...... so practically overclocking does not change anything... and most people who get their procy burnt will get it replaced without saying they overclocked it.... although this is illegal and i am not advocating this at all.....
@deathvirus_me
making such general statements does not serve a purpose, it obviously depends on the ram u have, if u have a poor ram, with poor read/write speeds, and the ram is already a bottleneck, and u are also sharing it as video memory... this will hold true for any processors and nothing to do with athlons......
but if ur condition is like mine... 1Gb 1.5CL ram running in dual channel, and video card has it's own memory at 21Gb/s and ram read/write speeds are already 6000Mb/s then it does not matter if i run it 20Mhz slower.... because ram is not a bottleneck for me..... so whatever processor it is, it will not matter...
well my stable speeds are
2.86Ghz @ 1.45v
2.8Ghz @ 1.4375v
2.6Ghz @ 1.31v ----------- (great for hot days)
Kniwor is offline
Old 14-05-2006, 12:45 PM   #10 (permalink)
samrulez's Avatar
Thanks Guys for helping me out.
samrulez is offline
