| Forum |
#1 (permalink) |
plz help me its urgent |
#4 (permalink) |
Laptoping
This is a common problem with 845 boards. All you have to do is get into the bios and reset to default settings. If you check out the help file, you will get the same recommendation.
You could think I'm wrong, but that's no reason to stop thinking. |
#6 (permalink) |
Laptoping
dude just get into the bios by pressing the del or F2 key whichever is applicable, and you will find that option in the BIOS. Save changes and restart. It doesnt get any simpler than this.
#8 (permalink) |
Laptoping
So did you reset the bios to default settings ? If you did so, things should work out.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
