Old 11-05-2006, 10:10 PM   #1 (permalink)
dOm1naTOr's Avatar
Default Logitech X530 5.1???Help....
I recomented the speaker Logitech X530 5.1 for my friend and taking my words he bought it today. But he is saying he is utterly dissapointed with its perfomance. It costs 5600/ here in Kerala, Kottayam. I thought it would be way better then Creative inspire 5200 as X530 has an overall power of 71 watts rms that is around 15 watts greater than creative and its advertisement is very attractive and it has cool looks too.
I think it might be due to the low quality of onboard sound chip (ASUS A8N VM mobo with Soundmax %.1 audio). Anybody got any idea. Do u think buying an additonal creative 51./7.1 24bit live s card would do justice to the speakers as it costs another 1700-1800.?????
PLZ reply immediately
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-05-2006, 12:09 AM   #2 (permalink)
dOm1naTOr's Avatar
The satellite speakers are somewhat OK and sounds better than the Creative but the woofer fails to impress.
But see the company web site:
http://www.logitech.com/index.cfm/pr...CONTENTID=9067
Here it given 25 watts woofer. But it lacks the punch and sounds worst tah creative 5200 woofer with 17 watts. But the creative was played on Intel High Def audio system.
So is it wiser to go for a sound card?
G3: XPS M1530 |
FZ 16.
Old 12-05-2006, 07:18 PM   #3 (permalink)
pedal to metal
suave_guy's Avatar
Default Re: Logitech X530 5.1???Help....
did u saw the performance of the speakers yourself??
ideally logitech is known for making subwoofers with deep bass(thats one of the reason logitech speakers are successful)
i've read several reviews on this speaker set and they all recommended this set and it sounds odd that its not performing better than creative 5200...
i wud recommend to check the settings of the soundcard, maybe he's using the equalizer and has set the low frequency(bass) to very low level or maybe he has turned down the volume level of bass from the speakers
you can also try to run these speakers on any other computer...
one cannot rule out the possibility of speakers being faulty...so make sure how they perform on any other computer...also try to watch dvds in 5.1 mode and check how's the performance
ENjoy...
your "attitude" is your best friend...
suave_guy is offline
Old 12-05-2006, 08:27 PM   #4 (permalink)
creative and logitech basss should sound good in games and not much good in general sounds
I like altec lansing 251 sound for music
chota_rod_waala is offline
Old 13-05-2006, 12:22 AM   #5 (permalink)
dOm1naTOr's Avatar
Yes today we took it to my home and I checked it myself. I personally own a 5200 but I think 5200 outperforms X530!!!4200 bucks outperforms 5600 bucks???
The X530 lacks punch. Just a huge vibration can be heard and it could shake the windows but we can't even recognize each punches seperately in music if volume level is near medium.
I think all branded speakers are under powered but its in the quality(build quality) and warranty support hat it rulzzzz. Local brands like PERX could be lot better in perfomance. We visited another shop and saw a huge 5.1 from PERX with vertical stand like sattelites and a huge sub. It costs around 6500 but its worth it after seeing its thunderous power. We could feel each punch in the music within our lungs.
Ive decided never to go for branded speakers.
G3: XPS M1530 |
FZ 16.
Old 13-05-2006, 01:10 AM   #6 (permalink)
royal's Avatar
Unhappy Re: Logitech X530 5.1???Help....
Thats really strange
Almost all the reviews I read said this speaker was good value for money and ideal for gaming and DVD movies (performance in music tests were ok)
Atleast it should have been better than Creative 5200
royal is offline
Old 13-05-2006, 10:20 AM   #7 (permalink)
pedal to metal
suave_guy's Avatar
aravind its not like that....u cant just move away from branded speakers coz of this reason alone, dont forget that ur creative set is working fine which is also branded...
i agree that there are some locally assembled powerful speakers available and no doubt that they will perform but the prob with almost 90% of these unbranded speakers is that they will perform well for first few months and after that they will just die out or will have other strange probs which will eventuall affect the sound quality....
so think again...
ENjoy...
