| Forum |
#1 (permalink) |
its showing 43 degree
P4 2.8 Ghz Asrock 512MB Kigston Pc 3200 Samsung 160 GB LG DVD WRITER Sony DVD ROM Samsung 45Bn |
#3 (permalink) |
No pain....No gain
Well my Seagate 80GB PATA (7200 rpm) idles @ 37C and max load @ 45C.
@deathvirus_me In ur signature I could see XFX 6800GS V'Cooled.........what's V'Cooled? Is it ANTEC V COOL (Slot cooler) that u are using. Pls reply. And what's ur idle and max temp.
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#6 (permalink) | |
tell me guys hot to lower it and also tell me if it harms my hdd in any case
#8 (permalink) |
-The BlacKCoaT Operative-
what utility do we need to chk hdd temp
-------------------------------------------- Holding my last breath, safe inside myself..... -------------------------------------------- I dont use my computer. I misuse it- रोलरकोस्टर |
#9 (permalink) | |
Speedfan .. google for the link will you ...
#12 (permalink) |
in load time its showing 68' and the fans are working fine
plz someone help
#13 (permalink) | |
http://search.ebay.in/search/search....adis=200&fsct= |
#14 (permalink) |
Make your own cooler for that sake. There are a couple of good tutorials in the tutorial section. Check those out. one is adding a fan just below the hdd and the other is adding heat sinks on hdd (thats if u have enough room)
#15 (permalink) |
guess what guys i have added 2 fans removed heat sink cleaned
applied thermal paste and put it back now my cpu temp is from 70 to 44 and hdd temp from 44 to 36
#17 (permalink) | |
#19 (permalink) | |
ya that was funny but as i told its working fine now so no need for any hilly area but thanks for ur advice
| Bookmarks |
| Thread Tools | |
| Display Modes | |
