Old 10-05-2006, 09:39 PM   #1 (permalink)
Default Antec True Power 2
can anyone tell me the price of Antec True Power 2 550w smps ????
one more thing, it has fan on upper side, not on back, why ?????
i have a simple cabinate ............
rahuljin is offline
Old 11-05-2006, 02:20 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Antec True Power 2
It's price is qouted at Rs.7200/- in ebay, check this http://cgi.ebay.in/Antec-True-Power-...QQcmdZViewItem
For more specification see this : http://www.case-mod.com/store/antec-...ly-p-1564.html
For user review look here : http://www.newegg.com/Product/Custra...82E16817103931
john_the_ultimate is offline
Old 11-05-2006, 07:51 AM   #3 (permalink)
Eazy's Avatar
I bought the Antec TP2 550w power supply last month in Mumbai for 7000/- from the local Antec reseller.
The 120mm fan on the inner side of the power supply throws air from inside the case over its PCB and out from the back - I dont think it needs another fan on the back as the air flow is quite sufficient.
It is the feeling of most Computer hardware experts that the Antec NeoHE 500 is a better power supply than the Antec TP2 550. Check the Neo out at...
http://www.theitdepot.com/categories.asp?cat=1011
Eazy is offline
