Old 10-05-2006, 07:27 PM   #1 (permalink)
Default All abt TV TUNERS ??!!
My config is:
AMD Athlon 3500+ 939
Asus A8N-E
SEAGATE 160GB SATA II + 120GB Samsung + 80GB Seagate External
ATI X800XL 256 MB PCI-E
2GB DDR RAM 400Mhz Tran
17" LCD Viewsonic
LITEON DVD writer
Microsoft keyboard + Mouse
Logitech MX 518
Steelpad Qck+ Mousepad
VIP1122 Cabinet with Atrix 500W SMPS
600 VA POWERCOM UPS
I wanted to see TV on my computer but have no idea whatsoever what the requirements are ..
do we need a cable connection ??
i know we need a TV tuner card , but which 1 ??
What details should 1 look for ..
do we need windows media center fr that ??
how easy is it to record programs ?? which format ?? size ?? software ??
what channels can we see ??
pls help me out also as to the price ranges available and what the difference is between as Rs. 1000 one to a 10000 one ...
CyCo is offline
Old 10-05-2006, 08:44 PM   #2 (permalink)
samrulez's Avatar
Default Re: All abt TV TUNERS ??!!
U just buy a new TV tuner and insert it in a PCI slot.You need a cable line which will go into the Tv tuner.In some cards there are additional features such as radio tuner etc.Make sure it is from a good Brand.
samrulez is offline
Old 10-05-2006, 10:37 PM   #3 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
No you wouldn't need any specific operating system 'media center ' or anything, inspite of what they like you to believe .
chesss is offline
Old 11-05-2006, 02:01 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Or u could even get external TV Tuners but they are a bit expensive than the internal tv tuner card. Some external tv tuner let u view channel without even using a pc, just connect the monitor (CRT/LCD) and convert it to a tv. One such product being AVerMedia TVBox 9.
john_the_ultimate is offline
Old 11-05-2006, 08:49 AM   #5 (permalink)
ramprasad's Avatar
I suggest an internal TV tuner if u have any plans to record programs.
Go for Pinnacle PCTV and u need the S/W provided by the TV Tuner card manufacturer to view the channels.
Regarding the no. of channels, it depends on the bandwidth (or rather range of frequencies) that ur TV Tuner supports and the list ur cablewala broadcasts.
The quality of recording will of DVD quality in most cards and size will be approx 40MB/min in DVD quality (720x576, mpeg4)
ramprasad is offline
Old 11-05-2006, 05:54 PM   #6 (permalink)
How much is the pinnacle PCTV , which model shd i buy .. and for a general cablewallah here , wha will b the freq ?? so i shd buy 1 that supports ...
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 17-05-2006, 04:52 PM   #7 (permalink)
ne1 kno nethin abt tv tuners ??
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 17-05-2006, 05:26 PM   #8 (permalink)
dIgItaL_BrAt's Avatar
Dunno about the exact price but the Pinnacle card costs around Rs 3000.
Also there is no special frequency as such,just plug in the cable wire that goes into your Tv into the card and scan for channels,justfbe sure to select the proper region in the TV viewing software,because the Frequency range it scans will depend on that.
dIgItaL_BrAt is offline
Old 17-05-2006, 09:11 PM   #9 (permalink)
chesss's Avatar
Hey anyone knows, whether a tvtuner requires a good video card.
My config: PIII 550, 256mb, 8mb Integrated video. Is this good enough to use a tvtuner normally, or will a better video card improve quality?
chesss is offline
Old 17-05-2006, 09:22 PM   #10 (permalink)
@chess: your configuration is good enough for viewing,but for capturing decent quality video u need a faster processor.
Integrated video will do just fine,but check if u can increase the dedicated VRAM,as it will offer better performance during video capture.
Old 18-05-2006, 11:16 PM   #11 (permalink)
Tushar.bar's Avatar
Thumbs down Re: All abt TV TUNERS ??!!
It dose't support recording! so why we give money fore those
Tushar.bar is offline
Old 19-05-2006, 10:35 PM   #12 (permalink)
which model of Pinnacle PCTV shd i buy ?? ne more details ?? cost + features
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 20-05-2006, 03:00 AM   #13 (permalink)
No pain....No gain
@Tushar.bar
Just giving him an idea that external tv tuner are also available. Cooldown man.........its just a suggestion and last decision is to be made by CyCo.
Old 20-05-2006, 06:58 PM   #14 (permalink)
i have an Ati X800XL ..i tht that it has a Tv tuner , but its just a Tv out ..
pls recommend on Tv tuners asap as will be buying end of this week .
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 20-05-2006, 09:28 PM   #15 (permalink)
vikasg03's Avatar
i have some confusion in my mind plz clarify and state pro nd cons.
in my knowledge there r 3 types of tv-tuner card 1. internal 2. external 3. TV box .
my confusion is wht is the difference b/w tv-box nds external card. is CPU is not needed in case of 3rd one?? and wht abut external card? cpu needed or we directly connect it to ouir monitor. and if we directly connect monitor to tv box or external card then how can we run our pc. IS i have to assemble/de-assemble every time i use PC/TV?
vikas
vikasg03 is offline
Old 21-05-2006, 01:05 PM   #16 (permalink)
@Cyco: Pinnacle TV tuner card is a good one. It costs around Rs 3,000/-. However, there are other cheaper brands such as Frontech. Try to purchase the TV tuner card with FM Radio tuning facility. After fixing the card you will only need to jack in the cable and install & configure the TV tuner card.
Abhijit
abhijitroy is offline
Old 21-05-2006, 05:44 PM   #17 (permalink)
Dude, Pinnacle Has 4 Cards .. check out the site .. so which model ??
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 22-05-2006, 10:28 PM   #18 (permalink)
Pinnacle PCTV Pro - I myself am using this card for about last three years. But as I said earlier, please check the TV tuner card with FM Radio tuning facility.
Abhijit
