Old 10-05-2006, 12:28 PM   #1 (permalink)
Default Ram for dual channel
I am about to pruchase a 256 Mb ddr for a 845 board i have. I already have a 256 Mb ram (ddr) running a 333 Mhz. I want to add another 256Mb in another slot. Even if i buy of 400Mhz it will be underclocked to 333 Mhz so thats not a pob. What i wanted to know is whether i have to take of the ram timings also ??? IS it necessary that the ram timings also match.
i m not OCing the ram
cyrux is offline
Old 10-05-2006, 12:35 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
Exclamation Re: Ram for dual channel
Rules to Enable Dual Channel Mode
To achieve Dual Channel mode, the following conditions must be met:
Matched DIMM configuration in each channel
Same Density (128MB, 256MB, 512MB, etc.)
Matched in both Channel A and Channel B memory channels
Populate symmetrical memory slots (Slot 0 or Slot 1)
Note: Configurations that do not match the above conditions will revert to Single Channel mode.
The following conditions do not need to be met:
Same brand
Same timing specifications
Same DDR speed
Note: Memory channel speed is determined by the slowest DIMM module populated in the system.
Source :
http://www.intel.com/support/motherb.../CS-011965.htm
mohit is offline
Old 10-05-2006, 12:58 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
Default Re: Ram for dual channel
btw 845 board does not support dual channel...
mohit is offline
Old 10-05-2006, 08:48 PM   #4 (permalink)
samrulez's Avatar
U R Mobo does not support Dual Channel mODE
samrulez is offline
- by soumya
- by tv6952
