| Forum |
#1 (permalink) |
!!!From DusT it StartS...... to DusT will EnD!!!! DusT = ME Rate me if was clear to you |
#3 (permalink) |
Learner
i dont think this will work... though the connector might seem to fit....
just give it a try
http://kniwor.wordpress.com/ |
#4 (permalink) |
i have a query:
i have a philips dvd player. the vendor says it is computer compatible. I wonder what does it mean by that? Can i connect it to my pc someway & be able to read dvd disks.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com |
#5 (permalink) |
Learner
just see what ports are there on ur player.... also let us know... a pic will be great and then may be we can figure out.....
the model of ur player is _______.
#7 (permalink) |
@parimal_xp2003 parimal_xp2003....
I want to use Tv as a monitor..... @ashfame I had connected my phillips DVD player to computer but using a tv tunner card.... i had connected the video out of the dvd player to composite of tv tunner... n then used the bundled software o view it.... @Kniwor main problem is tht i dont know where would i get tht cable...... i tried online searches but no indian shopping site has got tht cable.... also tht cable is for 4.99$ outside india... but the shipping is limited for america n uK only.... Eventhough some one has tht cable it would only work on HDTV (supporting high resolution) not ordinary TV... By chance it works than resolution will be limited till 800*600 ----> my guess BUt anyways please answer my question.... I am not confirmed wheter tht would work so im asking out u guys.... tht if anyone has tried tht.... ::::::SMILE:::::: ::::::LAUGH::::: ::::::ENJOY::::::
#8 (permalink) | |
#9 (permalink) |
yeah only watch movies..... n the functions of DVD player...
BY tht way its just like connecting DVD player to monitor instead of TV..... Please mention ur DVD player model no.
#10 (permalink) | |
Learner
it was a 29" thomson tv but the result was not too good, u can watch movies an all, the tv resolution is low as u suspect.... te fonts are hard to read as not clear, back then, i was a noob and was not interested in comps, so i dont remember how it was done by the guys.... but it was not anything impressive
#11 (permalink) |
GUys having high end graphic cards.....
Did u connect ur Pc to Tv.. If yes then whts d max resolution u got....
#12 (permalink) |
Learner
i dont think the gfx card limits the res.....
i will try it at earliest... thinking of doing this since some time
#13 (permalink) |
it limits cuz my frnd is having Fx 5200
n maximum resoution he gets is 800*600 blame it to 29" philips Tv or Graphic card... but tht true.... was wondering will tht remain same if we connect tht to HDTV....
| Bookmarks |
| Thread Tools | |
| Display Modes | |
