| Forum |
#1 (permalink) |
1. intel processor 2.8HT 2. 512mb ddr2 ram 3. mobo with onboard lan card & sound card & ddr2 compliant ram. it should also have a pci-e 16x slot for nvidia 256mb 6600. 4. Combo Drive 5. Cabinet with 300 Watts SMPS (is it enough?) 6. Monitor: Samsung SyncMaster 793S 17" 7. 160 GB 7200 RPM Seagate Barracuda 8. Standard Keyboard 9. Optical Mouse 10. 2.1 speaker set 11. fdd 12. ups (?? va) how much will it cost in delhi?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com |
#2 (permalink) |
-intel processor 2.8HT is no more available in the market now if i m not wrng..u can go for Intel P4-LGA 2.8GHz 533MHz,1MB,Non-HT-4900rs,or better Intel - HT P4-LGA 3.0GHz 800MHz,2MB,LGA-HT-8050rs.
-512 DDR2 667Mhz arnd 3k may b less. -945G with onboard GPU-ARND 6K,or 945P widout Onboard GPU..this shud b a better option if u plannin 2 go for a dedicated GPU. -i wont suggest u COMBO drive...instead get a seperate DVD-ROM & CD-RW.(SONY,LITEON) -300W SMPS is not at all enough..better get a 400w atleast,Powersafe 1.4k,antec arnd 3k. -Monitor: Samsung SyncMaster 793S 17"-6.4K -go for SATA instead of that barricuda.price diff is marginal.Seagate SATA 160GB 3.8k. -LOGITECH KB & Optical mouse .8k -Altec Lansing ATP3 2.1-2.8k -Atleast 600va UPS...800va will b gr8..betta backup. -i'll suggest u to go for 6600nu instead of 6200. Last edited by Aniruddh; 09-05-2006 at 08:48 PM. |
#4 (permalink) |
guys, i need a pc for my friend.
he has quoted a gaming pc for 35k including my profit. suggest me a one that is @ mid level with above config. @aniruddh i want 6600 not 6200. @royal read with your eyes open. who told ya that i am looking fora cd writer, i want a combo or dvd writer if margin is not much more. pl reply asap.
#5 (permalink) |
@ashfame...
Why the inclination towards Intel huh?? For gaming & other purposes also, AMD processors have shown far better results... As for Mid Range, check out the following Config & enquire about the rates, I am sure it shall be within 35 Ks Processor: AMD 3200+/3000+ MotherBoard: ASUS A8N VM / ASUS A8R MVP MSI RS 482 IL (With on-board GFX solution *cheaper*) MSI K8N RAM 512 or 2*512 Corsair/ Transcend/ Hynix(less preferable) CD-RW / DVD ROM (Preferable to go in for 2 separate ones): SONY/ Liteon HDD: SATA Seagate 80GB/ 160 GB GFX: NVedia 6600 256 MB Monitor: LG/ Samsung Keyboard/ Mouse: Logitech SMPS: 400 W Powersafe Cabinet: Intex/ i-Ball UPS: 600 VA powercom Speakers: 2.1 Logitech The above config in Nagpur comes out to around 38 Ks...The rates shall be far lesser in a place like Mumbai & the package should come within 35000. Peace HK |
#6 (permalink) |
@h_kunte
what about my profit then??? suggest only intel processors @ 533Mhz not @ 800Mhz. fsb Make it as cheap as possible.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com Last edited by ashfame; 10-05-2006 at 12:36 PM. |
#7 (permalink) |
U can go for the following AMD rig for arnd 30k:-
1-AMD64 3000+ (939 soc)=6k MAX 2-Asus A8N-VM/CSM=4/4.5k 3-2*256 DDR 400MHz RAM (kingston,Transcend)=2.6k 4-Combo Drive (Sony)=1.6k 5-Samsung 17'' Flat Monitor(798MB)=6.5-7k 6-Logitech MM KB & Optical Mouse=.8k 7-Seagate 80GB Sata HDD=2.7k 8-Creative Inspire 2.1 or Altec Lansing ATP3=1.8k/2.8k 9-Numeric 600VA UPS=1.8k 10-Cabinet of ur choice=1k-1.5k Above config will come around 30k...and this is a very decent rig. |
#8 (permalink) | |
what about gpu 6600?
#9 (permalink) |
All right, i have decided to buy the following:
1. Processor: P4 HT 3.0Ghz (1MB, 800Mhz FSB, Socket478 ) >>What Socket 478 means?<< >>Anyone who can quote its price for it in delhi !<< 2. Intel Mobo (onboard sound, LAN card & a pci-e 16x slot & DDR2 ram compilant) >>Suggest one compatible with above processor<< 3. Samsung SyncMaster 793S 17" CRT 4. Keyboard & Mouse (Logitech) 5. nVidia 6600 graphics card (pci-e 16x) >>Whats the difference in it & its gt variant?<< >>Also the price difference?<< 6. HDD 7200rpm 120-160GB >>Suggest the cheapest one !<< 7. FDD 8. DDR2 Ram (1x512) >>Which brand is the best?<< 9. Dual Layer DVD writer >>Suggest the cheapest one !<< 10. Cabinet with 400W SMPS >>Cheapest<< 11. UPS 800VA >>Which brand is the best?<< Components that i have quoted for being cheapest should also be satisfactory reliable!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com Last edited by ashfame; 10-05-2006 at 04:55 PM. |
#10 (permalink) | |
Back to School Mr. Bean !
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC Laptop: HP Pavilion dv8210us |
#11 (permalink) | |
#12 (permalink) |
@ashfame - a socket 775 processor would be better i feel though i've not used one till now. Maybe some other board member who's using that can confirm
#13 (permalink) |
Hmm ... the p4 stock cooler is quite noisy .. but thats the case only when it reached 4k's rpm ... if u keep it around 3.5k's the sound is barely audible .... better case cooling will surely make this possible ...
#14 (permalink) |
AMD Athlon 3200+..........................................750 0
Asus Mobo.............................................. ......6500 Cabinet........................................... .............700 SMPS Antec 350 watt.....................................1500 HDD 120/160 Gig SATA/SATAII..........................3500 Lit-on DvD burner...........................................2 750 Speakers Creative Aspire 2.1/4.1......................3000 GPU nVidia 6600/6600 GT...............................5000/7500 Keybo logitec........................................... ....300 Mouse logitec........................................... ....300 Monitor 17' Samsung.....................................6000 -------------------------------------------------------------------------- I'm not sure about the prices. |
#15 (permalink) |
Guys read previous posts carefully.
My friend is insisting on intel processors & mobo. Don't suggest amd's OK, as mod_the_pc said to go for socket 775 processor. @ mod_the_pc Suggest one by the name. @ deathvirus_me how much cooling cost would heat up the price? And can anyone tell me whats the diff. in P4 series & D series? Hurry up. I need to assemble my friends computer in two days!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com Last edited by ashfame; 11-05-2006 at 07:19 PM. |
#16 (permalink) |
Go for this..............
AMD 64x2 4200+ 2.2GHZ 512 Mb per core cache...RS 23500.. ANy 939 asrock mobo around 3500 with on board graphics and 80 gb hard disk 2800 and any cabinet with 350 watt power supply...rs 1500....3000 for the monitor 14 or 15 inch and a optical mouse 250 +keyboard 450.... presently i am using 64x2 4200+ with k8Neo4 Platt mobo..@ gig ram o/c to 2.7Ghz |
#17 (permalink) | |
If further AMD posts are posted then they all will be reported.
#18 (permalink) |
Wht about this:
Intel Pentium D 805 Dual Core Processor (2.66 GHz, 2MB, 533MHz FSB, Socket 775) Also suggest a mobo for it. (mobo with onboard lan card & sound card & ddr2 compliant ram) Pl also explain fsb details. And will the above processor work on a mobo with 1066 Mhz fsb. (Intel D945GNTLKR Motherboard) Does it has a pci-e 16x slot for nvidia 6600 & support for ddr2 ram sticks. is there any variant of above processor for 1066Mhz fsb. Urgent!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3 HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com Last edited by ashfame; 12-05-2006 at 11:57 AM. |
#19 (permalink) |
Can Intel D915GUXL Motherboard accommodate the Intel Pentium D 805 Dual Core Processor (2.66 GHz, 2MB, 533MHz FSB, Socket 775)
#21 (permalink) | |
Alive Again...
I dont know what it the cost of your PC in Delhi But just wanna say U that if you are investing in this much than go for 3.2ht y going for 2.8 |
#22 (permalink) |
Posts 20 & 21 are useless, just a effort of junior members to raise their posts count.
Pl read posts 18 & 19 before posting again.
#23 (permalink) |
My vendor has quoted me the following which i am suscpicious about:
1. Nvidia 6600 (256MB, pcie 16x) for Rs. 2800 ????????????/ 2. cabinet with 400W SMPS for Rs. 1200 ?????????????/ 3. Microtek UPS 800va for Rs. 1750 ??????????????//// Is he upto something? I mean how can he provide the above @ such prices. Is there something that he can cheat me about? Am i buying something @ cost of other feature? How do i assure myself? These are the prices @ nehru place, delhi. Pl help.
#24 (permalink) |
pl help me with the above post guys.
#26 (permalink) |
Alive Again...
Useful site for Delhi Resi.
http://www.npithub.com Here u'll find ur All Computer Accessories Rates & also ur 7k PC |
#27 (permalink) | |
Well thanks for your concern. Problems solved. Forgotten Threads Updated.
#28 (permalink) |
dont rely too heavily on npithub and the call centre i have personally experienced it 3 to 4 times
Game Khelwanu Magazine Padhwanu Majjani Life http://sudiptatech.blogspot.com/ http://sudiptamondal.blogspot.com/ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
