Old 08-05-2006, 08:19 PM   #1 (permalink)
Unhappy Problems With Moniter!!!! PLZ Help
Hi Everyone,
I've a problem which i dont knw where da cause lies...
I have a Intel 2.4 Mhz. 512 MB RAM, Asus P4VP-MX MOBO, 160 GB Hard Disk n a 256 MB Geforce FX 5200 graphics card.... but my computer wont boot!!! When i remove the graphics card the computer works perfectly.... but when i connect da moniter 2 da graphics card it wont boot... though my computer is upgraded my moniter is old its, a LG Studioworks 552V moniter...
I jst want 2 knw tat can n out-dated moniter cause such problems??? or is bcoz of da moniter socket in da graphics card or da AGP slot in da MOBO??? PLZ HELP!!!!!
hell_storm2004 is offline
Old 09-05-2006, 12:23 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: Problems With Moniter!!!! PLZ Help
I dont think there is any problem with the moniter or the card.... but I think it is a compatibility issue.... any other members got the same config.???? try and test the card on ur friends pc...this way u'll come to know whether there is a prob. with the card or it is a another compatibility prob......
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 09-05-2006, 01:10 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
This shouldn't be a problem but I think that ur gfx is 8x agp and ur mobo has an 4x agp slot so there could be voltage problem.
The 4x agp (AGP 2.0) has 1.5V whereas the 8x slot (AGP 3.0) has 0.8V. So sometimes this could be the problem.
Though 8x card is backward compatible to 4x,2x,1x but sometimes problem arises.
Since ur monitor is working, its fine, don't worry.
So get a 4x card or try another 8x gfx card and see if it works.
john_the_ultimate is offline
Old 09-05-2006, 05:29 PM   #4 (permalink)
Are u sure that the system is not booting. It may be booting, but the display is not there. You can try to switch your primary display device to AGP instaed of on-board from BIOS.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 10-05-2006, 08:44 AM   #5 (permalink)
Also try installing correct driver for the graphics card after uninstalling the drivers for onboard graphics.
V.Prem Kumar
janitha is offline
Old 10-05-2006, 12:31 PM   #6 (permalink)
Hi Everyone,
Well i got my pc booting.... i dont knw hw... all i did was change a BIOS setting in the Plug-n-Play devices section... there was an option called "Plug-n-Play OS" which was set to "NO" n i changed it to "Yes" n my computer booted for da first time in 5 days!!! then i formatted my drive n reinstalled windows n all da drivers but when i installed a game started it there was no display!!! i can hear the sounds of the game running in da background but there's jst no display!!! i dont knw hw this is happening as all of my drivers r installed properly!!! PLZ Help!!!!
Thanx for all the suggestions Guys!!!!!
Old 10-05-2006, 12:42 PM   #7 (permalink)
Display driver is the culprit here for sure.....try to update to the latest drivers
krish is offline
